587,250 active members*
3,582 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Techno CNC > Techno software, adjust z height mid program?
Results 1 to 8 of 8
    Nov 2004
    38
    Does anybody have a trick to adjust the z height of the tool mid program?
    The only way I can get it to work is to reset the file, which doesnt work very well wth a toolchange file.
    Jan 2007
    723
    No, I have not found a way to do it! I have run into instances when I would have liked to as well. I think it might be impossible with the way the techno software preprocesses files and sends them to the controller.
    Pause the machine...double click the "Z" axis postion reading on main screen and enter the amount of axiz change i.e. if you enter -.25 it will lower the spindle .25. Click "apply" and then "resume".
    Nov 2004
    38
    Cheers Tim, works perfect.
    Jan 2007
    723
    This is truly an awesome tip! Was it in the manual anywhere?
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Nov 2004
    38
    yes, its on page 51. You really should read your manuals!
    Jan 2007
    723
    I read it but that doesn't mean I understood it! Thanks!
    Nov 2007
    20
    Techno offset while mid program
    While running a Techno machine an offset can be created on any axis.
    Pause the machine, Double click on the axis you want to change ( x,Y,Z, etc) Type in a positive number to offset the cutter to cut higher, and a negative number to cut deeper.
    IE: I would type in -.1 to add that much depth to the cut.
    Be carefull because the axis will do what you tell it to.
    I forgot the point symbol once, and it indeed added 1 inch to the depth of the cut.
    It was dramatic!!!
  1. SCM Xilog adjust toolchange height
    By derek_Hampton in forum CNC Machining Centers
    Last Post: 01-04-2015, 03:44 AM
  2. Mach 3 manual height adjust
    By The_Fixer in forum Waterjet General Topics
    Last Post: 06-14-2009, 07:15 PM
  3. Replies: 3
    Last Post: 05-28-2009, 01:16 AM
  4. Replies: 0
    Last Post: 12-05-2006, 09:04 PM
  5. Tool Height Touch Sensor for Techno-Isel
    By mikkojay in forum DIY CNC Router Table Machines
    Last Post: 08-08-2006, 08:28 PM
