587,189 active members*
2,560 visitors online*
    Dec 2007
    8
    spaces between gcode O-M control
    (chair)Im trying to find out why when I save back a program to a laptop I get an extra line that does not have code on it. I dont have any problems with the other machines so the DNC software Im using must be set up just fine. does someone know if its a setting that Im not able to find or get to ? Its a O-M fanuc control. program looks something like this.
    G0X0.0Y0.0
    Z0.0
    G1X0.0Y0.0F15.0
    G0Z2.0
    Jan 2008
    136
    most likely is an additional line feed (LF) generated by the control, there may be a setting in the data in/out section of the manual to help. also, the laptop could be generating the additional LF, check the RS232 settings.
    2932
    Check parameter #0070 bit #7 (ICR). It's probably a 0, which punches LF + CR + CR. Change it to a 1, which should only punch a LF.
  1. Toolpath Spaces
    By Oldbill in forum Uncategorised CAM Discussion
    Last Post: 01-21-2008, 04:21 PM
  2. STL to GCode
    By Vixon in forum Uncategorised CAM Discussion
    Last Post: 11-11-2007, 05:41 PM
  3. DIY Router Control/GCode Generation?
    By IAD in forum Uncategorised CAM Discussion
    Last Post: 02-23-2007, 03:46 AM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
