I found a connection for these servo motors
Would they be any good for cnc router with 3 1/2 porter cable engine I have started to purchasing components for my routers
I need 12 servos for to 5 axis routers and 2 rotary indexers I am building and I think it is important to get all the same servos it
says there 5/8 of a HP
x y and z axis in my design are thk rail and .2 lead ball screws
2 to 1 ratio
4-6th axis will be appox 10 to 1 timing belt set up custom machined components
It all sounds nice to me but this is a big chunk of money for me
I still do not understand what I am looking at in these specs
and i have been reading all the posts on servo motors
And I want Everyones opinon Please
They are $150 with encoders
Reliance Electronics
part # 721-015-0774
model#E712
Torque Constant Kt 37.51 +/- 10% Oz-in/A
Back EMF Constant, Ke 25.0-30.5 V/KRpm within 400mv CW to CCW
Motor Terminal Resistance .75-1.02 Ohms @ 4A.
Nominal Voltage Rating 60V
Nominal Speed Rating 2100 RPM
Maximum Peak Torque 1500 Oz-In.
Maximum Peak Current 44.5A
Maximum Continuous Stall Torque At Max Motor Temp 300 Oz-In.
Maximum Continuous Current 8.9A
Motor Inertia .15 Oz-in-sec
No Load Current at 50v .90A Max
Maximum Winding Temp 155 deg C
Shaft End Play .001" Max with 20lb load
Four replaceable brushes.
Motor Body 5.675" Long, 4.0" Diameter
Shaft 1.3" Long, 0.5" Diameter.
1.5" Diameter Positioning Boss, 4 10-32nd Mounting Holes on 2.5" Diameter.
Thanks to all With knowledge that Help me Decide if these are a worthy investment
Mace
