587,524 active members*
3,240 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Tangent Arcs Mastercam 9.1
    Aug 2007
    Hi. I am using Mastercam V9.1 SP2 to mill out a handle out of plastic. I construct two 0.25 circles 1.0" from each other with a tangent arc or fillet with a 3.0" diameter between them. Each time I select create\arc or fillet\tangent\2 entities, type in 1.5 for the radius, select the two arcs I get many white circles around the two 0.25 circles. The 3.0" circle or fillet never gets constructed. I am not sure what I may be doing wrong, if anything. My guess is there is some sort of setting that will recognize what I want. Can anyone help? Thank you for your time.
    Apr 2003
    1876
    Quote Originally Posted by taa1967sma View Post
    You're not taking it far enough. The multiple white circles are all the different ways that 1.5" radius can be tangent to those two circles.
    All you have to do is click on the white circle you want to keep and the rest will go away.
    HTH.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Aug 2007
    Thank you, thank you, thank you!!
    Matt,
    I can't thank you enough!!
    Troy
  1. Arc tangent to an Arc
    By Bob Z in forum Mastercam
    Last Post: 02-26-2009, 10:48 PM
  2. Drawing a tangent to two curves
    By accellodyne in forum Mastercam
    Last Post: 12-02-2008, 06:52 PM
  3. Tangent lines joining two arcs
    By yongchiprsnapr in forum Mastercam
    Last Post: 11-30-2008, 11:39 PM
  4. line tangent from...
    By Castle1 in forum Rhino 3D
    Last Post: 09-21-2007, 02:08 AM
  5. tangent point
    By bob in windsor in forum MetalWork Discussion
    Last Post: 12-23-2005, 10:05 PM
