587,776 active members*
2,708 visitors online*
    Jul 2007
    macro programing
    Hi can any one help me i need to wite a programto ingrave a part that i am machining on a haas. The engraving consists of a part number that increases by 1 every time e.g. part number AAAAA1, AAAAA2, AAAAA3, AAAAA4, up to AAAAA2000, Is there a way to program this with a macro program that changes the program automaticly.
    Jul 2005
    12177
    If I remember it correctly in your G47 line you put P0 and then (######) for what will be engraved.
    Then before running the program go to Current Commands, page down twice, enter 599 and write. This brings up the page with all the macro variables. You type in the starting number you want to use and press Write. If this does not work get back to me tomorrow; we do sequential serial numbers all the time.
    You don't have to have macro enabled to use G47 you should be able to specify all your info on the G47 line.
  1. Boss programing
    By Minnesota HD 10 in forum G-Code Programing
    Last Post: 12-16-2007, 03:39 PM
  2. 0-M programing help please
    By venomgrrrl in forum Fanuc
    Last Post: 12-08-2007, 06:51 AM
  3. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
  4. CNC programing
    By Fryzss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2007, 04:33 PM
  5. CAM programing
    By kenlambert in forum G-Code Programing
    Last Post: 02-03-2006, 07:03 AM
