586,305 active members*
3,525 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA LR-15 OSP5020L axis disable
Results 1 to 6 of 6
    Nov 2012
    2
    Can anybody tell me how do I disable one of (2) double drives(BLII-D) on a Okuma lr-15 with a 5020L control ?
    Nikola
    Apr 2009
    1262
    Re: OKUMA LR-15 OSP5020L axis disable
    Machine lock and e-stop disable...I think on the lathe the only other way is to unplug it, but then you will get an alarm. What do you hope to accomplish?
    Nov 2012
    2
    We have an ALARM has shown: 201-8 SERVO AM MA-AXIS 2C6.
    The servo amplifiers for both M-axis are damaged.
    Since we do not use those two axis I would ask you to help me how, if it is possible, we can disable/remove these two M-axis from the configuration of the machine, or make some bridges on the connectors of the servo amplifiers, so that the alarm would not appear at all and we will be able to use the machine without those axis?
    Jun 2015
    26
    To enable an Okuma 5000 or 5020 with a BL-D or BDU drive removed, jump pins 13,14 & 10 on CN1 (connector that goes to the circuit board) together to mask any alarm. Then jump 19 & 20 on CN10 (goes to the drive base) connector together to enable the bulk Power supply. MAKE SURE YOU GOT THE RIGHT PINS, OR YOU WILL DAMAGE YOUR MACHINE. Great way to use a machine with just the upper turret or without an A axis.
    To enable an Okuma 5020 with BL2-D drive removed, jump pins 8 to 10 on the XB1 connector(s). For a dual drive you have to jump both connectors. We do this all the time so we can test one BL2-D5050A dual axis drive on our 4 axis Okuma 5020 control. We rebuild & exchange almost all Okuma servo drives. CNC Repair With Engineering Excellence Since 1988
    Quote Originally Posted by doctorcnc View Post
    Hello Doctorcnc, i am trying to disable an axis as you dicribed, but on the CN10 there are only 5 wires going to that connector, and they are on 1,2,3, 6,7. If i connect 19 and 20, there are no wires.
    Hi Kotronik, did you have success with the procedure as by doctorcnc? Please let me know, i have same problem, and my problem is that CN10 is wired only on 1,2,3,6,7. and not on 19&20
  1. x6 Okuma lathe osp5020l
    By 1neil in forum Mastercam
    Last Post: 03-31-2014, 01:03 AM
  2. Okuma OSP5020L DNC problem
    By Hemi8146 in forum Okuma
    Last Post: 10-18-2012, 02:44 PM
  3. Okuma LNC 8 with OSP5020L
    By robsmetalcraft in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-15-2010, 02:22 AM
  4. Okuma OSP5020L
    By MKATool in forum Okuma
    Last Post: 06-27-2008, 06:05 AM
  5. Okuma OSP5020L Backlash compensation
    By Rocksalt in forum DNC Problems and Solutions
    Last Post: 02-12-2006, 02:13 AM
