587,543 active members*
4,343 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Leadshine MX4660 Mach 3 Setting
    Mar 2017
    I have a Leadshine MX4660( Leadshine Technology Co., Ltd.) and it was working good with Mach 3.
    I had a motor bind up and it went into Protection Mode.
    I have a single red light Flash on my X axis and a 3 red light flas on the other 3 axis.
    How do I get it to reset? My Mach 3 controller software wont let me reset due to E Stop.
    Jul 2016
    18
    Re: Leadshine MX4660 Mach 3 Setting
    Hi gcnc588,
    If the red light flash one time, that means this module is over current. And if after power on, can not remove this error, then this module maybe damaged.
    Try to restart the drive, if the error can not be removed. Try another new module !
    Thanks.
    Oct 2015
    6
    Hi ,
    gcnc588 you found a solution? I also facing the problem any leads?
  1. Motors don't run - Mach3- Leadshine MX4660 - UC100 USB
    By pilotarix in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2022, 06:46 AM
  2. Replies: 27
    Last Post: 04-18-2018, 11:59 PM
  3. Replies: 8
    Last Post: 04-13-2018, 08:48 PM
  4. Replies: 9
    Last Post: 08-30-2015, 01:23 AM
  5. Nema34 electronic for a 48x60 build with Leadshine MX4660 and KL34H260-60-4A
    By javabugz in forum DIY CNC Router Table Machines
    Last Post: 10-16-2014, 04:21 PM
