You can do it. It is a little cumbersom. Hopefully I can keep it simple. Here goes.
do a letter like you are trying to put it in the 12 o'clock position. Then copy the block for however many letters you have then use pattern rotate before the second letter and rotate the second letter 10 or 15 degrees. Then after the letter do a pattern end. You have to look and adjust each letter. For example W and I take up different spaces in the lettering and require a different gap. So W may need to rotate 12 degrees and I only 8 to look the same as two O's side by side. This should do it, if not pm me and I will try to explain more or in a better way. Hope that helps. I also do training on the Hurco controls if needed. Jetski
Jetski (alias Tooling and Engineering Czar)
"I may not have the keys to success.. but I have learned to pick the locks"
