587,817 active members*
3,110 visitors online*
Thread: tolerances
Results 1 to 13 of 13
    Jan 2007
    51
    tolerances
    When a tolerance is not called out on a print for hole location, what is the industry standard?
    Oct 2004
    48
    There should be a spot in the heading that says all other tolerance.
    Jan 2007
    51
    no tolerance listed on print except for the cut length of the part
    Mar 2005
    1136
    the answer requires context. this might be viewed as an aberration in commercial circles, it is common if not the norm in model engineering/home shop plans where the builder does have complete knowledge of the mating parts and function. you pick a fit based on the intended purpose
    edit: I'd add to that answer, if tolerances aren't stated they can be inferred from the number of significant digits in the dimension, but it would help in answering if you described the type of plans, part, function etc as if they are diy plans tolerances and clearance are usually up to you
    Oct 2006
    586
    Quote Originally Posted by jprobst View Post
    You may have to refer back to the customer "better to be safe than sorry"!!!!!!
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Mar 2006
    2712
    I agree with jackson. I've seen where a complete book of "standards" is supplied with the RFQ. Many large companies have their own standards for materials, coatings, plating, dimensional tolerances etc. So, like jackson said, better to be safe etc.
    DZASTR
    Jul 2006
    18
    99% of the time you'll be safe with +/- .005, and if they are reamer holes that are to be spaced a certain distance apart, we get +/- .0005. If you have a cnc and type in the right coordinates, you should be fine. Unless the piece is not on size.
    Aug 2005
    578
    There is no "Industry Standard" if it isn't on the drawing then you need to call the customer. End of story. Assuming a number will get your parts rejected.
    Jul 2003
    263
    Quote Originally Posted by PBMW View Post
    general machine shop practices dictates +.003/-.002 on hole sizes up to .25 in dia from .251 dia tolerance is +/- .005 but most company have their own tolerance standards that they follow and is supplied with their RFQ
    If you can ENVISION it I can make it
    Feb 2007
    381
    Yesteryear, that may apply. Unfortunately, more and more I am finding that companies are deviating from the norm and using their own tolerances. We have jobs that run in our shop that have 3 place decimal tolerances of +/- .015 on down to +/-.001. It just seems to depend on the customer and what their needs are as to what their "standards" are. When in doubt, always ask the customer. As said before in this thread, better to be safe than sorry. A phone call is a lot cheaper than having to run the job over because it was assumed.
    :cheers:
    Nov 2005
    1468
    When you do contact the customer, get it in writing. If you feel akward asking him to put it in writing then write to him yourself saying "further to our recent conversation, I confirm that we shall hold tolerance on dimension X to +- whatever".
    I love deadlines- I like the whooshing sound they make as they fly by.
    Oct 2006
    586
    Quote Originally Posted by ImanCarrot View Post
    Yes or just have them e-mail or fax another copy of the print that has it written on it such as .250 drill +.003 / -.001 PER. John Hancock
    Aug 2005
    249
    If the tolerances are not specifically called out I would state, in writing, what tolerances you expect to achive at the price the job was quoted. If the customer has any comments you simply tell them that that was how it was quoted and you may need to re-evaluate the quote.
    BTW, why is this in the HAAS forum?
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
  1. Tests for Shoptask tolerances?
    By pfarber in forum Shopmaster/Shoptask
    Last Post: 04-05-2007, 11:26 PM
  2. Acme thread tolerances
    By DayneInfo in forum DIY CNC Router Table Machines
    Last Post: 12-30-2006, 07:56 PM
  3. Spindles, bits, and tolerances
    By sploo in forum Commercial CNC Wood Routers
    Last Post: 08-12-2005, 06:22 PM
  4. Tolerances of CNC
    By millberg in forum DIY CNC Router Table Machines
    Last Post: 02-23-2005, 11:16 PM
  5. Scaling tolerances
    By Ken_Shea in forum OneCNC
    Last Post: 05-15-2003, 01:28 PM
