587,827 active members*
2,953 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > G83 won't rapid to the bottom of hole?
Results 1 to 8 of 8
    May 2009
    Hello all,
    I'm new here and to machining, but have been CAD/CAMing in solidworks/camworks for a few months and have some ?s.
    I'd like to drill a 2mm hole through 0.75" quartz on my HAAS VM2, and man, using G83 is likely to take upwards of a week with the required feeds at F0.06 IPM (10,000RPM).
    The lengthy time comes from the fact that after the rapid retract, my machine feeds back to the hole bottom at the stated feed rate. Is there a way to RAPID back to the bottom of the hole, say 0.020" above the floor? That would cut time down by 95%.
    Damon
    Nov 2007
    1702
    What value do you have in setting 22?
    Greg
    Apr 2009
    29
    Please subscribe us with the values set on settings 22 and 52 and the part program and so we can help you.
    Cheers!
    Jun 2009
    5
    g73 (high speed peck drill??)
    May 2009
    I found out what was wrong, at least i think so. G83 worked like it was supposed to, but Setting 22 was set too high (0.050in). With a feed rate of 0.06 in/min, and a a depth of 0.8, it was set to take weeks (almost literally) to do. I changed the setting to 0.005 and the task took a more reasonable time.
    Here's the code that i've got:
    O0001
    N1 G00 G90 G20
    N2 T07 M06 (2.0MM Diamond DRILL)
    N3 S10000 M03
    N4 G00 G54 X0 Y0 S10000 M03
    N5 G43 H07 Z.02 M08
    N6 G83 R.02 Z-.8 Q.001 F.06
    N7 G80 Z.03 M09
    N8 G91 G28 Z0
    N9 G28 X0 Y0
    N10 M30
    (this is all kicked out from Camworks- HAAS Post)
    All it is is pecking down to 0.8" deep. It's a small drill in a very hard material, but i don't have access to center-cooling bits. so, i'm relying on a retract to flush out debris and insert coolant on each plunge.
    Anyone have any ideas on how to speed this up a bit?
    Damon
    4826
    Sounds a little like drilling glass, so maybe a soft core drill technique would work: obtain some steel tubing (like a hypodermic needle) and diamond paste, and core drill the hole. Now a machining center is maybe not the right machine for the job, a simple drill press with a weight hanging on the lever, while the thing runs merrily away, eroding its way in.
    Jun 2009
    5
    we use to interpolate small holes -.75 and deeper with core drills and thru spindle coolant on our quartz .........worked great. with out t.s.c. your pretty limited.
    May 2009
    Quote Originally Posted by +/-? View Post
    you are 100% right! TSC is about 5 times faster, but we only need to do this a few times. So the cost isn't justified.
  1. Taig mill bottom base mounting bolt hole spacing pattern
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 01-20-2009, 09:42 PM
  2. Replies: 9
    Last Post: 02-11-2008, 05:54 PM
  3. Milling top and bottom?
    By bigvinney in forum MetalWork Discussion
    Last Post: 01-28-2006, 04:16 PM
  4. Look at my bottom
    By Graham S in forum DIY CNC Router Table Machines
    Last Post: 12-14-2004, 09:12 PM
  5. Ok so what is the bottom line?
    By WallCrawler in forum Community Club House
    Last Post: 06-19-2003, 03:51 PM
