587,704 active members*
3,495 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 198 Alarm (Precharge Failure) TSC Not Working
    Nov 2009
    71
    We have a VF3 with coolant through the spindle and have been having issues with a hum from behind the spindle head with an unclamp alarm. I replaced the pre-charge solenoid and cleaned things up about three weeks ago and the machine was fine for a while until the second solenoid went bad and now we are getting the same problem a hum and tool unclamp alarm. Can the I/O board be bad? What else can I do to figure out the root cause?
    When I disconnect the pre-charge solenoid the machine tool unclamp alarm clears but then we get another alarm TSC pre-charge failure. Might not be a good Idea but can we bypass the pressure switch just to get a job done thats on the machine now?
    Feb 2012
    TSC Issue.
    Hi Eric.
    The solenoid is activated with 115 VAC. if the voltage is low it will make a humming noise. It will also make the noise if the pre-charge air pressure is not set correctly to 3.8 PSI. The way that you set the pre-charge air pressure is by installing a gage with a T fitting. The pre-charge air line needs to be connected if not it will alarm out with a pre-charge failure. I can assist you more effectively if you call the Haas Automation Inc service line at 1-805-278-8500 prompt #3 for service.
    Oct 2015
    6
    Re: 198 Alarm (Precharge Failure) TSC Not Working
    Vf3 had high gear fault going off intermittently, Worked fine in high and low gear, just got the fault regularly. Took the solenoid assembly out, regulator with the small orifice, air manifold to the copper pipes with the small orifice, main air supply assembly and 3 solenoid/valves all came out and cleaned. High gear alarm stopped but the first TSC tool threw the precharge failure alarm. When I manually activate the TSC solenoid, coolant dumps in the spindle somewhere, leaks out around a shaft. Anyone help me out?
  1. EMCO MAXXTURN 65 alarm 2079 TURRET referencing failure
    By samirabaza in forum EMCO Lathe
    Last Post: 04-07-2014, 04:15 PM
  2. Y axis grid align failure - alarm 44-6
    By paneltec in forum Cincinnati CNC
    Last Post: 01-19-2012, 08:20 PM
  3. TSC Precharge Failure alarm 2000VF3
    By dingo0722 in forum Haas Mills
    Last Post: 11-21-2011, 09:49 PM
  4. ATC TURRET FAILURE and ALARM
    By scadvice in forum Fadal
    Last Post: 03-29-2011, 05:36 AM
  5. Leadscrew Map Checksum Failure Alarm
    By kwmkoester in forum HURCO
    Last Post: 06-03-2009, 12:58 PM
