Anybody figure out how to get bob cad to print out set up sheets.Tool list,fixture offsets ect.
I'm working on a little something. There's a lot of ways to get it done, just figuring out the most efficient way.
Very cool thank you.
Dave
Since this would be a true setup sheet which (in my opinion) should always include material cut size, I need to ask an opinion on how you guys setup your stock in BobCAD.
Do you guys use selected geometry for "Stock" or do you right click on Milling Stock - Edit to set the X and Y width? Or do you not set the stock at all?
The real question I guess is would you rather the script try to read a stock size from the file or just enter the stock size manually in an input box?
when i do use it i right click milling stock.
