587,659 active members*
3,195 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad V25 using Woodruff Key Cutter how to use a BobCad "T-Cutter"
    Oct 2010
    31
    Question BobCad V25 using Woodruff Key Cutter how to use a BobCad "T-Cutter"
    Hi, I've only used BobCad with ball nose and end mill cutters. Today I'm trying to program for Woodruff key cutter using the Mill 2 Axis / Profile package. I can create the cutter in the tool libraries, but I can only select end mills in the profile package.
    I've used BobCad a very long time but I must have missed something on selecting other tools when needed.
    Can someone give me some information on how to select other tools types in the profile package.
    Jun 2005
    656
    Re: BobCad V25 using Woodruff Key Cutter how to use a BobCad "T-Cutter"
    Basically you can't in that version of BCC unless you have 4th-axis Pro. You have to fake it with funky short and wide "end mills" and smaller diameter tool holders.
    http://www.cnczone.com/forums/bobcad...86-bobcad.html
    http://www.cnczone.com/forums/bobcad...-t-cutter.html
    http://www.cnczone.com/forums/bobcad...l-cutters.html
    http://www.cnczone.com/forums/bobcad...ot-cutter.html
  1. Replies: 7
    Last Post: 11-24-2014, 07:41 PM
  2. Replies: 0
    Last Post: 11-10-2014, 04:26 PM
  3. BobCad V24 "Select Geometry" problem
    By chuckmole in forum BobCad-Cam
    Last Post: 03-06-2014, 04:17 AM
  4. Replies: 14
    Last Post: 12-29-2011, 09:01 PM
  5. Bobcad "catastrophinc" error on reinstall
    By ind_dsnr in forum BobCad-Cam
    Last Post: 07-21-2011, 11:51 AM
