587,149 active members*
5,389 visitors online*
    Feb 2009
    4
    Exclamation Mazak Quick Turn 6T
    We have a Mazak Quick Turn 6T w/Mazatrol 640t......
    I'm tring to get the dnc or even the tape feature to work I have been able to communticate with windows using HyperTerminal and direct link all within windows. Does anyone have any working prameters that I might be able to try Thanks........
    Feb 2009
    4
    Had some luck with the tape feature I can send a file(cnc-->PC) with no problems, but when I try to receive (cnc<--PC) I get a error 549 (data size over) I'm using dnc4u prog.
    Thanks for any help
    Feb 2007
    198
    640T has one meg of std memory.
    a standard floppy disk has 1.44 mb. a floppy should be able to handle all your data in/out needs, yes?
    for serial info - one funky thing on mazatrols is theres one stop bit one way and 2 going the other. and thats the extent of what i know about the subject.
    if you get me your email, i'd be happy to send some handy rs-232 documentation to you.
    -jim
  1. Mazak quick turn nexus 250ms 640t control
    By sidecar82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2012, 08:30 PM
  2. mazak Quick Turn
    By NellyB in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-23-2009, 08:56 AM
  3. Mazak Quick Turn 15 leaking air?
    By revlimit in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-25-2008, 06:04 PM
  4. Mazak Quick Turn 350
    By T.J in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-10-2008, 12:14 AM
  5. Mazak Quick Turn 350
    By T.J in forum MetalWork Discussion
    Last Post: 05-14-2008, 12:19 PM
