587,086 active members*
2,989 visitors online*
Results 1 to 7 of 7
    May 2008
    4
    Mazak Quick Turn 350
    Have a new QT 350 and want to find out if the is a M code to close the door (without holding both buttons) that is no forbidden.Or how to change parameters so this can be done.
    Apr 2008
    44
    for standard machine does not have M Code for door close or open
    if u want to trying M56(door open) & M57(door close) but that is option not for standard
    May 2008
    4
    we have found the m 56 &57 but a message comes up that m 57 i a forbidden m code,i assume this is a safety function but do not want to stand holding the 2 door close buttns so i did think there may be a way around thisto close the door with the cycle start button as this machine has so many safety functions that the only thing i cant get caught in the door is my prick
    May 2008
    4
    can i also ask some advice on cutting a lefthand thread as i cant find anything in the mazatrol programming functions
    992
    Quote Originally Posted by T.J View Post
    the same way you cut righthand thread, except cut with tool travel backward back to front.
    The best way to learn is trial error.
    Apr 2008
    44
    that right push 2 buttom for door close is a safety,but i have QTN 200 can use M56 & M57 because my boss bought it for option
    for left thread,may be you can reverse the sequence of start point and end point or you can reverse the rotate
    for example:
    right thread start point z0, end point z25 may be you can reverse it to start pointz25, end point z0
    Jul 2007
    10
    i think there's another way for doing left hand thread you should use left hand tool and the spindle direction is in reverse and the program is the same as right hand thread start z0.0 and final z25 assuming the length of the thread...
  1. Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1'
    By Haaatschi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2021, 01:33 PM
  2. Mazak quick turn nexus 250ms 640t control
    By sidecar82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2012, 08:30 PM
  3. Mazak Quick Turn 350
    By T.J in forum MetalWork Discussion
    Last Post: 05-14-2008, 12:19 PM
  4. Freqrol FR-SX Mazak Mazatrol T4 Quick Slant 20
    By machinist360 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-02-2008, 06:51 PM
  5. mazak slant turn 40n
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2007, 09:16 AM
