587,083 active members*
2,990 visitors online*
Results 1 to 16 of 16
    Mar 2005
    335
    1/2 speed and No torque
    I have a chester conquest of the 2005 era.
    it seams to have a KBIC control board.
    The problem that the machine has little speed and even less torque, the spindle can be stopped with my hand. Any ideas, i have tested the power resistors and they seam to be OK.
    And ideas?
    24223
    It sounds like you may have an open side on the control bridge components, there is two SCR's and two diodes in the bridge.
    Did this just happen?
    Al.
    Mar 2005
    335
    yes it did just happen.
    i was parting off and the tool snatched and stopped the head causing the head to stall and break a couple of teeth in the headstock. The motor was stall for about 5 -10 seconds.
    after replacing the gears and changing to taper roller bearings. I thought i might as well when the machine is in bits i put it all back together to find the current situation.
    matt
    Mar 2005
    335
    now just slow speed even if the pot on the control is in the off position.
    Jun 2004
    6618
    I have had a pot go bad. They have the switch inside as well as the pot. Just cheaply made. I had to order a couple replacements from little machine shop.
    Lee
    24223
    Quote Originally Posted by fragger6662000 View Post
    The fact it happened due to a stalled motor indicates the power side may have been damaged, Once you have it corrected, you may want to make sure you have the correct limit resistor in place and the current limit pot is set correctly.
    The limit resistor is sized according to motor HP.
    Al.
    Mar 2005
    335
    the speed control pot is ok, as i have just checked it.
    Mar 2005
    335
    Right i have track down the problem to the SCR as you stated in the first post.
    the only problem that i have now is that i cannot find an equivalent part and cannot find a data sheet for the current part. Does anyone know a different part that can replace A69108.
    thanks matt
    24223
    They are not really that critical, in fact I repaired a Bridgeport by fitting larger components off board on a heat sink.
    Look for 300~400v 10 to 20 amp SCR's, you may have to do a little reverse engineering to come up with the pin out polarity, but they are generally standard pin out.
    There is 2 SCR's and 3 diodes. The diodes are fitted with 3 leads also.
    Al.
    Mar 2005
    335
    i found the data sheet for the diode and they are fine. i have never had so much trouble finding information on a single component as this one. thanks for the information.
    matt
    24223
    I forgot to mention they are Teccor components, I think they are now owned by Littlefuse.
    Al.
    This is a long shot but if the electronics check out you may want to check the pre-load on those bearings. I am just mentioning this because I had rebuilt a lathe headstock and had similar results. I decided to check the mechanical side first and loosened the bearing pre-load. Ooops, saw the SCR post after...
    Carvejunky
    Mar 2005
    335
    the pre load on the bearings is ok. they just need a little running in as the grease needs to be moved about.
    Mar 2005
    335
    right.
    according to the KB people the current direct replacement is S8015L or S8020L and at £2.50 each it was not too bad.
    thanks for the help.
    24223
    Handy to know, thanks.
    Al.
    Mar 2005
    335
    well the progress now is the DC motor and board is dead.
    i have purchased 3 phase inverter and motor and in the process of hooking it up to the machine with different toothed belt and pulleys.
    i tried v belts and found that they slipped too much.
  1. Micro torque converter to slow router speed
    By technomage in forum DIY CNC Router Table Machines
    Last Post: 08-07-2013, 07:34 AM
  2. Torque Speed Curve
    By Imbue in forum Automation Technology Products
    Last Post: 01-04-2011, 12:34 AM
  3. Benefit of Speed and Current(Torque) PID loops ?
    By andy55 in forum Servo Motors / Drives
    Last Post: 08-13-2006, 05:07 AM
  4. High speed torque
    By JFettig in forum Stepper Motors / Drives
    Last Post: 11-04-2004, 02:15 PM
  5. Question of Voltage vs. Torque/Speed
    By ullbergm in forum CNC Machine Related Electronics
    Last Post: 07-28-2003, 07:36 PM
