587,753 active members*
3,058 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > It seems my linear bearings don't fit...
Results 1 to 14 of 14
    Jan 2004
    236
    Of course when I measure with calipers I get
    bearing id = .495
    shaft od = .495
    cheap calipers btw...
    I haven't taken a hammer to them yet, but trying to press them on by hand, I can't do it.
    Maybe my mistake was buying those ceramic coated bearings. I just called and some real linear bearings are on the way...
    So what do you guys think about those ceramic coated thingies?
    Mike...
    P.S. You can see, I am getting the stuff together for my first machine!
    2139
    Make sure there is no burrs on the shafting where they were cut. They are designed to be tight. Use a little oil.
    Eric
    I wish it wouldn't crash.
    40
    I change the wheel bearings on my motorcycles and when I do, they are also a very tight fit. I normally need a bearing driver to install them. Put the bearings in the freezer for a few hours. It'll still be tight but oh so much easier to install.
    David J. Morrow
    May 2003
    109
    Ummm, Freezing makes things shrink, not expand, he would have to put the rod or rail in the freezer for that to work.
    Being that I do a lot of automotive work I commonly use a electric griddle set at 350 degrees, lay the bearing on for about 7-8 min and they will slide right on, just be sure the are all metel bearings, and contain no plastic.
    40
    Yes, I see your point. When I put the wheel bearings in the freezer, they are then inserted inside the hub of the wheel. So, the shrinking affects the outside diameter of the bearing which is where I want it but not where you want to insert a shaft.
    David J. Morrow
    Jan 2004
    490
    Freeze your delrin before tapping for drive nuts, and it'll not only be easier to tap, but it will expand enough upon warming to make travel a bit easier without adding backlash!
    Stop talking about it and do it already!!!!!
    Jul 2003
    151
    Shrink Fit
    Um, actually, a common misconception it that the unit shrinks. This is not the case as precived. The outside diameter shrinks but so does the inside diameter. Things should slide on nicely when cold enough. The ratio is very small, however. I have worked with liquid nitrogen to achieve the required fits. @ -390 and below things can seem amazingly sloppy. The diagram kinda shows what acutally happens. The blue represents the original size of any round object. The red isn't necessarily to scale.
    _Doug
    Uh, 3 sheets to the wind, I'm afraid....
    4826
    Its funny, but I apparently had the misconception that he wanted the shaft to slide through the linear bearings. All this shrink fit advice is good for making a permanent fit for a tire on a railroad wheel, though
    Jan 2004
    490
    It is definately a good way to press fit things. In street rods, some brake kits come with aluminum hubs and steel rotors. You put the rotor in the sun, and the hub in the frezer, then they go together easily. This is how the company says to do it too, so I would assume that the inner di. of the rotor expands when heated. It still isn't much with metal, few thou maybe.
    Jan 2004
    236
    Hey Guys,
    I have a simple little Thomson harden shaft... and an even simpler little ceramic coated bearing. No moving parts at all...
    So lets see, I heat the shaft in the oven, cool the bearing in the freezer, lose my case hardness, and wear grooves into the shaft. Nope that's not what I want to do.
    Okay, I'll freeze the shaft, heat the bearing in the oven... nah, forget it... I'll just wait for the other bearings to arrive!!!
    ***UPDATE***
    I had all my parts sitting near the window overnight. Here in Michigan it's been quite cold... Do you know that this morning every bearing fit onto every shaft. And they glide and slide wonderfully!!!
    Mike...
    P.S. So the only question remaining is which bearing is better? The ceramic ones, pictured below, or the linear bearings with the little bearing balls in it?
    Jul 2003
    151
    Hi Mike,
    Glad to hear it worked out for you! Ah, cool pics and ceramics, too! Those have a certain drool factor in my book.
    As far as which is better I'd bet it would depend on which salesman you were talking to. Anyway, I favor the ones you have. I am curious about lubrication. Do you leave these dry? Going to be a lot easier to ensure how clean they stay if thats the case.
    Good luck with your first machine!
    -Doug
    (not even hung over)
    4826
    Ah, then it was just a case of the newbie not being able to align the shaft with the hole to start with. When you said it wouldn't go on, I assumed you meant it, and therefore all the shrink fit advice was pointless, because it would have resulted in permanent fit. If a shaft and bushing will slide, its got .0005" clearance or more. It can be tricky to get it lined up though.
    Jan 2004
    236
    I did mean it!!! I wasn't trying to put a square shaft into a round hole.
    The problem resurfaced today when I starting assembling the z axis. On of the 12" steel shafts didn't fit the bearings again. So I got out the calipers again. It seem that this shaft is .005" too big. So I wasn't crazy...
    Anyways, it's going back, and I'll have the new shaft in a couple days.
    Whew!!!
    Originally posted by HuFlungDung
    Ah, then it was just a case of the newbie not being able to align the shaft with the hole to start with. When you said it wouldn't go on, I assumed you meant it.
    Jan 2004
    236
    I want to tell you guys, McMaster Carr is fast. We called them yesterday evening... 6:00 PM is evening, right? Anyways, the parcel arrived this afternoon, with the replacement parts. Now is that FAST or what?
    So I'm going back downstairs to play!!!
    Mike...
    Whew!!!
  1. Linear Bearings
    By 2muchstuff in forum Linear and Rotary Motion
    Last Post: 07-13-2008, 08:24 PM
  2. Bearings for home made linear
    By Alaskan in forum DIY CNC Router Table Machines
    Last Post: 08-14-2005, 07:09 PM
  3. Need help on linear bearings
    By bbergami in forum DIY CNC Router Table Machines
    Last Post: 05-26-2004, 12:04 AM
  4. Nylon Linear Bearings and shafting
    By Jcadwell in forum Community Club House
    Last Post: 04-15-2004, 02:29 PM
  5. Linear Guides with Teflon Bearings
    By cely in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2004, 11:05 PM
