587,913 active members*
3,704 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Dill feature without center drill feature
Hybrid View
    Sep 2007
    182
    This seems like a really easy one but I cant seem to fiure it out. When using the regular drill feature I cant seem to get it to just do a simple drill operation without doing a center drill operation first. The only way I have been able to do it is manualy remove if from the code, there must be a better way?
    Keith
    Dec 2008
    4548
    In CAM Part-Milling Tools, right clcik and choose Part-Toolpattern and select the feature and remove the op... This is for the current Document... If you want it to be "Always Global" then you would set this under "Default" instead of Part..........
    Sep 2007
    182
    Ahh, thats perfect. Thx
  1. feature cam to dxf
    By daleman in forum FeatureCAM CAD/CAM
    Last Post: 07-15-2011, 02:59 PM
  2. Feature Cam
    By albasha mohmed in forum Uncategorised CAM Discussion
    Last Post: 11-01-2010, 04:18 PM
  3. cut feature
    By hall6ppc in forum Solidworks
    Last Post: 05-28-2009, 03:00 AM
