586,983 active members*
2,760 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    May 2006
    86
    Custom Base Build
    Howdy,
    Just went down to Gem State Metals and picked up 222 pounds of steel for my custom base design. This is most of the steel needed for the base. The process begins. I'm thinking this is an addiction.
    kr
    http://www.parmarng.org/freeidaho/default.html
    http://xlforum.net/vbportal/forums/showthread.php?t=999415
    May 2006
    86
    Re: Custom Base Build
    Howdy,
    I had a bit of time in the shop this weekend. All the drilling is done on the front and back frames, and they are tack-welded together. I'm pretty excited about the result. They are square and true, and identical. The square and true part is a function of patience, clamping, and always measuring everything three times or more times before tacking. The identical part is easy, since the second frame is built by clamping all the pieces to the first frame. Attached are some pictures if y'all are interested.
    Next step is to finish weld these frames without warping them, but that is all planned out.
    Attachment 236878
    Attachment 236880
    Attachment 236882
    Attachment 236884
    Attachment 236886
    kr
    Nov 2010
    291
    Do you have a drawing of your plans? Are you going to in corporate a full enclosure into your design?
    I have the deluxe base already and there are enough enclosure ideas out there for that. Just wondering what the final outcome would be for you.
    May 2006
    86
    Howdy,
    I posted plans in this thread some time back.
    http://www.cnczone.com/forums/tormac...ew-please.html
    They are basically the same now, but with a few tweaks.
    What do you ride?
    kr
    Nov 2010
    291
    I do remember seeing that thread.
    I ride road bikes training for triathlons and have a Softail for now.
    May 2006
    86
    Howdy,
    After a day in agony, a trip to the ER, and a day of rest... actually yard work, I finally got to do some finish welding on one frame. Much less progress than planned, but some progress none-the-less.
    I hope y'all had a good weekend.
    Ken Reed
    Nov 2010
    291
    Sorry to hear all of that! Hope you got it all worked out...and keep that head covered so that doesn't lead to the ER!
    Jan 2012
    789
    Ooh bummer man! What happened?
    Oct 2006
    13
    Ken,
    Build looks like it's going good. Looking forward to more pictures of your build. Hope the ER visit wasn't too serious. Keep up the great work.
    Nate
    Nov 2007
    2151
    Looking good! Going to be solid .
    I have the upper chip pan and back splash off my mill for service.
    Not real easy to get at the bolts and I have full access to back of my machine.
    Glad I set the machine with full access because in my experience you need to remove all the upper trays just to get at parts of machine for maintenance and upgrades.
    I would keep this in mind when designing and building your base and chip trays / enclosure. Allow access for inspection, adjustment and repair of ball screws, oil lines, electrical and pneumatics on a regular basis.
    md
    Oct 2011
    477
    Quote Originally Posted by mountaindew View Post
    md
    Mountain,
    Not trying to hijack the post but you guys might consider this to improve access.
    I had the same issue with the upper Chip Pan and Back Splash. The way they cross the back of the machine makes service and upgrades difficult plus it blocks access to the ATC controls.
    I attacked mine with mace and mallet and eliminated the portion behind the column and electrical cabinet. I laid out the panels and cut them apart with a saber saw. I then rejoined the cut parts, welded and ground the corners and painted to match. The new panels are then bolted to the column and electricall cabinet using the original holes in the edge of the rewelded panels.
    I think it turned out well and now gives full access to the back of the macine while sealing off the Splash Guard.
    nitewatchman
    Nov 2010
    291
    That is a great idea nitewatchman! I was looking into something similar when coming up with my full enclosure (still under construction).
    May 2006
    86
    Morning,
    Back to build progress. Well a bit of progress to show. The base structure is finish welded, square and true. Pictures from the past couple months.
    Attachment 257058 Attachment 257060 Attachment 257062 Attachment 257070
    Just got the metal for the Tormach CNC milling machine base coolant tray home yesterday in the storm. It is ready to be bent, welded and attached. Easy to say, but a bit of work to keep it straight and not leak. I know, I know, what could be so hard to bend on the dotted line and weld?
    Attachment 257064 Click image for larger version.
ID:	257104 Attachment 257068
    The big hole in the coolant tray is the coolant filter area. There will be a sheet box welded to the underside of this that will hold the strainers and filter material. I'm going to have a lot of coolant flow to handle.
    Sep 2012
    1543
    Great website
    Nov 2010
    291
    Quote Originally Posted by BAMCNC.COM View Post
    Great website
    Agreed! Bookmarked here.
    I need to look over your plans in the other thread and see what I want to do for an enclosure. I just want something NOW to contain chips. Too much deliberation and over analyzing leaves one empty handed!
    Feb 2006
    7063
    Here's the enclosure I built for my machine:
    http://www.cnczone.com/forums/novako...ml#post1400930
    Took about 3 hours to build, and cost about $50 in materials. Works perfectly - 100% containment, and it can be completely removed or installed in under 5 minutes.
    I initially used a shower curtain for the "door", but a while back built proper sliding Lexan doors, using home-made "glides" and aluminum T-track:
    http://www.cnczone.com/forums/novako...ml#post1552350
    Regards,
    Ray L.
    May 2006
    86
    A little bit of progress today. There is 9" of snow outside so no riding the Harley today.
    These are pictures of the coolant collection box fabrication. It is tack-welded together and is square and true. I don't have a break so these were bent by hand over some angle iron. The coolant box has two floor drains in it that flow the coolant back into a tank underneath. That is all for today.
    Attachment 257120 Attachment 257122 Attachment 257124 Attachment 257126
    Feb 2006
    7063
    Having experience with a number of milling machines, some of which had rather poor drainage, I have one suggestion: You can never go "too big" on drainage. My current machine started with a 4" diameter round drain, which filled up with chips and clogged constantly! I now have a roughly 12" wide x 18" long drain opening directly under the machine base, which never clogs. This is one of the rare cases where bigger IS better.
    It's not clear where your collection box is located, but if it is under the machine, you'll have a hard time clearing a clog in those two (2"??) drains. I would suggest allowing at least 2-3" clearance UNDER the machine to facilitate easy cleaning, and put the drains where they are very easily accessible. If I were designing an enclosure, I'd slope the whole thing in one direction, so I could simply use a hose to wash all the chips from the entire enclosure to one side, and down into a BIG opening feeding into a separator, with an easy-to-remove chip bin.
    Regards,
    Ray L.
    May 2006
    86
    Ray,
    Those are the drains, not the filters. The whole box, contains a 14" x 28" filter, and the coolant goes through two extra fine 10" diameter cooking strainers before it gets to the filter material.
    This box is beside the mill, like Tormach's base, but 10x as big. Yes, there is a slope to the coolant tray that goes under the mill.
    Jan 2010
    251
    Quote Originally Posted by freeidaho View Post
    Ray,
    i read that in your post at the top, some don't pay attention. good work.
Page 1 of 2 12
  1. CRP PRO 48x24 DIY Custom Build. First CNC Build.
    By OrangeClockwerk in forum Avid CNC
    Last Post: 11-06-2014, 11:58 PM
  2. Custom made precision mill with epoxy-granite base
    By circaeng in forum Epoxy Granite
    Last Post: 01-26-2012, 10:05 PM
  3. Project: Aluminum Eater (Scratch Build) - New XY-base frame design!
    By LBSamurai in forum CNC Wood Router Project Log
    Last Post: 12-06-2011, 10:47 PM
  4. New build - base on SX1L or X3?
    By small.planes in forum Benchtop Machines
    Last Post: 06-14-2009, 08:20 PM
  5. An IH build, base to table
    By ozzie34231 in forum Charter Oak Automation Support Forum
    Last Post: 05-31-2007, 11:05 PM
