587,402 active members*
3,215 visitors online*
    Feb 2013
    Mazatrol: best way to upload/download progs
    We recently purchased a 1994 Mazak SQT 15M with a mazatrol T+ controller.
    I am looking for the simplest way to upload and download programs.
    Can anyone help me with this?
    I spoke with Mazak applications and man in technical help told me that simple DNC software is adequate for this but as I read some of the older threads in this site... I am now a little confused.
    Will simple DNC software do the job? and if so, can anyone recommend a particular software that is proven to work for this controller?
    thanks,
    mike
    Feb 2013
    We use a software called Camlink to save all our programs to a computer and also to download them to the machines. This works for every mazak we own, which include two mazak vtc-20b mills, an integrex with the fusion control, three 10m plus controls, two Qt-8n controls, etc. Only limitations are that you can't take a tplus program and put it on an older control, or a mill to a lathe control obviously. However we can put the 8n programs onto the tplus seamlessly. Never had a single issue and it works pretty fast too. Another useful software is griffo brothers, which allows you to view the mazatrol programs on a computer and print them out onto paper, which is useful for when your programs can't be transferred to an inferior control. Hope this helps.
    Feb 2013
    Thank you
    Mikeyg, can't thank you enough for this information. I will research the leads that you have given me and I will let you know how we make out!
    Thanks again!
    Mike
    torresr Guest
    hi i been using by 2 years a Cimco software, for me works very well
  1. panarobo upload/download software
    By 323ci in forum RC Robotics and Autonomous Robots
    Last Post: 01-09-2024, 06:14 PM
  2. Replies: 14
    Last Post: 10-09-2011, 12:21 PM
  3. Can Download but Not Upload??
    By amf1277 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-01-2010, 04:00 PM
  4. Mazak M32 Comms Upload-Download
    By Mr_Carpyman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-25-2006, 07:50 PM
