587,124 active members*
4,420 visitors online*
Results 1 to 12 of 12
    Jan 2012
    Speeds and feeds for steel
    Hello, I am going to be machining some 4130 here soon. I have mostly done aluminum. My question is, how do I calculate the speeds and feeds for steel. I have a calculator on my phone, but it doesnt go off material just tool size. I normally ran the machine at 1500 to 2k for aluminum, but with steel, think this may cause problems. I am using master cam, so it gives me some basic numbers, but I know I can usually bump em up. Im just wondering how high I can bump em. I will be running the part on a HAAS TM1. Thank you.
    May 2004
    4519
    The basics for this come from Machinery's Handbook or your tool vendor.
    Jan 2012
    Ok, found a website and it calculated to about 1200 RPM for a 1/8 endmill and 800 for a 1/2 endmill.
    May 2004
    4519
    Those are pretty good starting numbers.
    Jan 2012
    Does anyone know of an app for the Iphone, that would list the cs for materials? I dont want to have to keep pulling up the internet to check for different materials. Thank you.
    May 2004
    4519
    Maybe save the relevant tables as documents?
    Dec 2006
    406
    What kind of tools are you using. Hss, carbide? Coated or uncoated? That makes a big difference. Your numbers seem low for carbide but are not far off for hss.
    Judleroy
    Nov 2005
    56
    Tooling manufacture
    It all depends what you are doing and with what tools, Running carbide 110m/min 0.05 a tooth will cut most steels but you can go alot faster than that. Speak to whoever you buy tooling from tell them what tools your using, depth/width of cut and they will give you the proper speeds and feeds.
    If your local rep is useless google whoever makes you tooling they normally publish spped and feed data online.
    Jan 2012
    Im going to run hss, then thinkin of moving to carbide if the first few parts come out right. Also, this question may be opening a can of worms, but who makes good tooling that is made in American. Thank you.
    May 2004
    4519
    All of the major tool vendors supply made in USA tooling. Just check their catalog listings.
    Jan 2012
    Thanks, ill have to talk to some peoplw and see what they have. I hate payin for oversees stuff when we make it here.
    Dec 2006
    406
    Try discount tools online. They sell tools that are made here.
    Judleroy
  1. hsm speeds and feeds
    By dek in forum PowerMILL
    Last Post: 07-10-2011, 09:58 PM
  2. Feeds and Speeds help
    By gmessler in forum Material Machining Solutions
    Last Post: 02-01-2011, 08:31 PM
  3. Speeds and Feeds for ASTM A-500 Grade B Steel
    By nfrees114 in forum MetalWork Discussion
    Last Post: 02-26-2010, 05:05 AM
  4. feeds and speeds
    By JpBinc in forum MetalWork Discussion
    Last Post: 10-03-2006, 06:48 AM
  5. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
