587,096 active members*
7,042 visitors online*
    Dec 2017
    6
    Torq cut 22 axis move to far
    Hi I just recently picked up this machine did a USB conversion on it got everything working correctly the machine homes correctly tool changes etc.
    When I go to run a program it gets through the first few lines to change to the correct tool and fires the spindle up. Then I receive this error
    dpCom: commanded x axis move too far positive.
    So I look at the code saying to get to x at 6.67" which with an x axis travel of 22" this shouldn't be a problem yet the machine gives me the error. I've tried doing some dry programs from previous owner and received the same results.
    Is there something I'm missing in the setup stages?
    Here is a picture of the error. Ignore the screen I'm in this is after several minutes of mashing through menus looking for something related to machine coordinatesthinking it may be possible it's trying to cut the program from the home position.
    Also the garage I stuffed it in
    Attached Thumbnails Attached Thumbnails 20171207_213315.jpg   20171206_191344.jpg
    Nov 2004
    164
    Re: Torq cut 22 axis move to far
    I had this happen before more notably in the Z axis and most often when I am previewing the program in the on-board simulator. I know this will sound weird, but just try jogging that tool to those coordinates or just past it on the x axis and try running the program again. Like you got to prove to the machine that it can indeed move that far. It works for me when I get that error every now and then.
    Dec 2017
    6
    i got her figured out. my only experience with machines like these is an onsrud router so I had to remember steps i needed to take.
    so the trick here was to set G54 at its home position then use g55 to tell it were the 'material' was and bam ran like a charm!
    if the community is interested i can post up a procedure on how to operate this thing from loading programs to setting up the material location etc.
    this is an extremely impressive machine from the 90's. with proper programming i believe it could still be a competitive and useful machine in the shop
    Nov 2004
    164
    Quote Originally Posted by tw1st3d View Post
    I like ours, but the rigidity on the Z axis is the week link in my opinion, and any 3D machining gives her a real work out and the spindle really screams at top end, but eventually it will get the job done. Rigid tapping and thread milling features and any 2D work out well for us.
    Jun 2011
    152
    Sure, the instructions would be helpful for new buyers/users. And I completely agree. with the right care and a little cleanup these machines compete favorably with machines 4-10 times their price. they are a really good way to get into cnc.
    Richard
  1. Hitachi Seiki Z-Axis ITZ Input Off, Z-axis will not move
    By markalbert70 in forum Hitachi Seikis
    Last Post: 10-09-2017, 07:28 PM
  2. Y axis doesn't move while all the other axis move...why?
    By Elsa in forum Mach Software (ArtSoft software)
    Last Post: 11-15-2014, 09:41 PM
  3. Replies: 7
    Last Post: 01-22-2013, 07:14 PM
  4. how to move the Z axis
    By cob in forum Mach Mill
    Last Post: 08-23-2008, 01:56 AM
