587,224 active members*
3,056 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > epoxy granite vs natural granite
    Jul 2014
    67
    Hello
    What is better for vibration damping stiffness accuracy etc the natural granite or epoxy granite ?
    Because for me natural granite costs much less than epoxy granite...
    For a cnc router 2m X 1.5m table sides and grantry is enough 12cm think granite or must go with 16cm thickness ?
    I will use hgr20 rails with 1605 ballscrews with rotating nut not rotating ballscrew.
    Jul 2018
    6461
    Re: epoxy granite vs natural granite
    Hi MR - If you have access to natural granite and can work natural granite then that's the way to go. Its stiffer and more stable then EG. For that size machine I think you should use 25 or 30mm rails not 20mm. Peter
    Jul 2014
    67
    thank you.
    What do you think about thickness of granite for this size machine? 12cm is enough or needed more for example 16cm ?
    Jul 2018
    6461
    Hi Mrsa - 120mm of granite is a very stiff chunk of material. For a router I'd expect it to be fine maybe even a bit over what's needed. Will be a heavy chunk of material!! Peter
  1. epoxy granite sliding on epoxy granite.
    By Eldon_Joh in forum Epoxy Granite
    Last Post: 05-30-2022, 12:13 AM
  2. FEA for epoxy granite.
    By ardenum in forum Epoxy Granite
    Last Post: 02-23-2021, 10:28 PM
  3. Epoxy Granite / Quartz Granite Mixes & Tests
    By made2hack in forum Epoxy Granite
    Last Post: 03-19-2018, 09:11 AM
  4. A new epoxy granite CNC
    By muppy in forum Epoxy Granite
    Last Post: 07-02-2015, 11:46 AM
  5. Why is there so little going on in Epoxy Granite?
    By CaptainVee in forum Epoxy Granite
    Last Post: 06-23-2015, 03:28 AM
