587,875 active members*
3,422 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Intermittent stepper control problem with G540
    May 2010
    98
    I am building my second CNC router and am re-using my Gecko G540, steppers, and cables from my first machine, where they worked with no problems. I am using Mach3 with an Xbox360 controller to manually position the router. It uses a USB port and interfaces with a plugin that someone wrote for it in Mach.
    One of my axis just starts taking off without any input from me. It is not a constant velocity and may or may not stop on its own. I swap cables on the G540 and the problem follows the G540 channel, not the stepper/cable assy.
    Does anyone have any ideas on what the root cause might be? I have searched various forums, google, etc. and either I'm not using the right search terms or no one else has seen this.
    If the DRO's in Mach3 are not changing while the axis is moving, then it's not coming from Mach3.
    May 2010
    98
    So I'm a novice and don't know what DRO stands for but if you mean the coordinates on the main page, then yes, they are changing.
    Sounds like the XBox controller is causing it then.
  1. Intermittent stepper problem
    By HomerSimpson in forum Mach Software (ArtSoft software)
    Last Post: 03-10-2011, 04:49 PM
  2. Intermittent pauses at every 1.8 degree for stepper motor
    By fujima4 in forum Stepper Motors / Drives
    Last Post: 03-05-2011, 03:41 PM
  3. G540 spindle control problem
    By rewster in forum Benchtop Machines
    Last Post: 12-19-2010, 12:14 AM
  4. Powermax 1000 intermittent "no start" problem
    By MoparJon in forum Waterjet General Topics
    Last Post: 12-17-2008, 09:59 PM
  5. Stepper control problem
    By climberfreak66 in forum Stepper Motors / Drives
    Last Post: 10-30-2006, 12:24 AM
