587,427 active members*
7,089 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Seeking advice on GE/Fuji AF-300 VFD
    Dec 2004
    12
    Can anyone give me some advice on this VFD (GE/Fuji AF-300 E11)? I am looking at using it for the 2.2 KW, 3 hp motor on my Shizuoka ST-N.
    Attached is the 2 page brochure.
    I would think it should work for my application. It is a cheaper drive (no encoder input), but I wasn't planning on doing rigid-tapping anyway.
    Is there any big disadvantages to this drive?
    Attached Files Attached Files
    24223
    It takes up to 3hp in single phase so it should work.
    The encoder on the motor back to the drive is used for precise speed control and torque down to low rpm, for rigid tapping you would also need an encoder on the final spindle shaft back to the CNC controller, or Z axis on a mill.
    Al.
    Sep 2008
    25
    Fuji used to manufacture GE's AF-300. But now Fuji has their own version called FRENIC Mini.
    http://www.ctiautomation.net/FUJI-FR...-Inverters.htm
  1. Prospective Machinist Seeking Advice
    By Septimius in forum Community Club House
    Last Post: 02-26-2010, 07:57 PM
  2. SEEKING ADVICE
    By kling8 in forum WoodWorking Topics
    Last Post: 11-19-2009, 09:19 AM
  3. Seeking advice on installing a QCTP
    By Thazul in forum Mini Lathe
    Last Post: 03-28-2009, 07:53 AM
  4. Seeking advice on motor/electronics package
    By endgrainguy in forum DIY CNC Router Table Machines
    Last Post: 02-12-2008, 05:33 AM
  5. Seeking Minilathe QCTP Advice
    By HankB in forum Mini Lathe
    Last Post: 02-09-2008, 03:29 AM
