Has anyone else gotten a vertical post which wasn't finish ground on the gib side of their dovetail?
I've been fitting a custom gib and lo and behold I found that the inside surface of my dovetail wasn't finish ground on the gib side of the vertical slideway. Blew my mind. The fixed saddle side is a nice smooth finish, but my gib side has a rough milled finish with no finish grind. To top it off it's got a 0.009" taper from end to end on the slideway which means I can't get a good gib adjustment without binding or slop on one end.
I measured the taper by measuring the gap outside a pair of 0.500" dowel pins resting in the taper so they register against the important surfaces.
