Hi CrazyRich
I answered you already in a pm, but for public record, you should not have any insurmountable problems.
The Camsoft interface can be customized or altered to do about anything, so you'd just have to make sure that your gcodes are set up to work exactly as they would on a FANUC, and you should be good to go.
I'd be careful about running OneCNC to do some heavy calculations while the machine is running though. It could hog the whole cpu for a few moments. I suppose if you've got your computer set up with Win2000 or WinXP, you'll be better off in such circumstances, than using the older Win9x series.
You won't have to use RS232 communications, of course. Just save the nc file from OneCNC (call it *.job if you like) and then find it and open it inside the Camsoft gui.
