586,900 active members*
2,798 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Mar 2008
    3
    Elliptical interpolation
    I would like to use elliptical interpolation in my Hitachi Seiki VA Machining running under Fanuc 6M-B.
    Is there a G-code for this ?
    If not, how should I proceed ?
    Thanks,
    Pramod Kotwal
    Oct 2009
    78
    Quote Originally Posted by pramodkotwal View Post
    Thanks,
    Pramod Kotwal
    Perhaps you should use CAD/CAM to generate an elliptical tool path.
    Ron
    Oct 2012
    21
    I have this software for ellipses. Saves money on a big CAD CAM system if you don't already have one. CNC Mate :: Engineers Calculator
    Ben
    http://www.cncapplications.co.uk
    Jan 2005
    1943
    Do you need a true and perfect ellipse? If not, you can approximate an ellipse with 4 arcs. That is how paper draftsmen used to do it. If you search Google for "4 arc ellipse" it will bring up the technique.
    Jul 2003
    1220
    Attached is a VB program which will generate GCode for an ellipse.
    Attached Files Attached Files
    Jan 2015
    7
    Re: Elliptical interpolation
    Greetings!
    I badly need help for generating G codes(G03) for a CNC 2-axis lathe for turning a ellipse out of a rod. The Rod dia is 12 mm and the ellipse (Full Ellipse) size is 11.5 mm height and 20 mm width. The G-code required is for the section shown in the attachment. The start point is at 0,0 and continues in the Z- axis till 10 mm (Half width of the ellipse). Any help would be appreciated.
    Attachment 263986
    Thanks in Advance.
    Jul 2003
    1220
    Hi I'm a mill user and don't know lathe programming, but here is a suggestion for a start. Check before running.
    G01 X0 Z0
    G03 X-0.008 Z-0.349 R15.2271
    G03 X-0.062 Z-1.045 R17.1512
    G03 X-0.174 Z-1.736 R19.3102
    G03 X-0.342 Z-2.419 R18.7294
    G03 X-0.562 Z-3.09 R18.0439
    G03 X-0.838 Z-3.746 R16.782
    G03 X-1.164 Z-4.384 R13.9492
    G03 X-1.54 Z-5. R13.8463
    G03 X-1.966 Z-5.592 R14.6919
    G03 X-2.438 Z-6.157 R11.3843
    G03 X-2.954 Z-6.691 R9.9005
    G03 X-3.512 Z-7.193 R8.9369
    G03 X-4.108 Z-7.66 R7.7523
    G03 X-4.74 Z-8.09 R7.7858
    G03 X-5.406 Z-8.48 R7.4939
    G03 X-6.102 Z-8.829 R5.7312
    G03 X-6.822 Z-9.135 R4.7587
    G03 X-7.566 Z-9.397 R4.7233
    G03 X-8.33 Z-9.613 R4.2145
    G03 X-9.11 Z-9.781 R3.8193
    G03 X-9.9 Z-9.903 R3.6358
    G03 X-10.698 Z-9.976 R3.7419
    G03 X-11.5 Z-10. R3.3543
    Jan 2015
    7
    Quote Originally Posted by Kiwi View Post
    G01 X0 Z0
    Thanks for the reply. I am specifically looking for X, Z, I , K value type of stuff. Secondly, can you recompute the values ? The total height of the ellipse is 11.5 mm and width is 20 mm. The required size is for half ellipse: height 11.5 mm and width 10 mm only. Your code is showing total height of the ellipse as 23 mm.
    Thanks in advance.
    Jul 2003
    1220
    Hi
    I thought I read somewhere the X was a diameter figure.
    Try this.
    G01 X0 Z0
    G03 X-0.004 Z-0.349 I-15.2271 K0.
    G03 X-0.031 Z-1.045 I-17.1483 K-0.3167
    G03 X-0.087 Z-1.736 I-19.272 K-1.2141
    G03 X-0.171 Z-2.419 I-18.6282 K-1.9444
    G03 X-0.281 Z-3.09 I-17.8581 K-2.583
    G03 X-0.419 Z-3.746 I-16.4883 K-3.1261
    G03 X-0.582 Z-4.384 I-13.5928 K-3.133
    G03 X-0.77 Z-5. I-13.3337 K-3.7327
    G03 X-0.983 Z-5.592 I-13.9276 K-4.6768
    G03 X-1.219 Z-6.157 I-10.6189 K-4.1037
    G03 X-1.477 Z-6.691 I-9.0396 K-4.0381
    G03 X-1.756 Z-7.193 I-7.947 K-4.0882
    G03 X-2.054 Z-7.66 I-6.68 K-3.934
    G03 X-2.37 Z-8.09 I-6.4282 K-4.3929
    G03 X-2.703 Z-8.48 I-5.8622 K-4.6683
    G03 X-3.051 Z-8.829 I-4.2286 K-3.8685
    G03 X-3.411 Z-9.135 I-3.2582 K-3.4684
    G03 X-3.783 Z-9.397 I-2.9026 K-3.7262
    G03 X-4.165 Z-9.613 I-2.2626 K-3.5557
    G03 X-4.555 Z-9.781 I-1.7037 K-3.4183
    G03 X-4.95 Z-9.903 I-1.2687 K-3.4073
    G03 X-5.349 Z-9.976 I-0.8719 K-3.6389
    G03 X-5.75 Z-10. I-0.4005 K-3.3303
    Jan 2015
    7
    When I open the G-Code in jviewer or SketchNC, I am seeing the following instead of a curved line
    Attachment 264068
    Is this ok or is some post processing required on the G-Code ?
    Thanks in advance.
    Jul 2003
    1220
    Hi
    Is your software able to check arcing on the XZ plane?
    I may not have converted the IJK correct to suit your XZ plane.
    I don't have software to check for paths on XZ plane or for a cnc lathe.
    Try this. I've changed the X to positive
    G01 X0. Z0.
    G03 X0.004 Z-0.349 Z0. I-15.2271 K-0.
    G03 X0.031 Z-1.045 I-17.1483 K-0.3167
    G03 X0.087 Z-1.736 I-19.272 K-1.2141
    G03 X0.171 Z-2.419 I-18.6282 K-1.9444
    G03 X0.281 Z-3.09 I-17.8581 K-2.583
    G03 X0.419 Z-3.746 I-16.4883 K-3.1261
    G03 X0.582 Z-4.384 I-13.5928 K-3.133
    G03 X0.77 Z-5. I-13.3337 K-3.7327
    G03 X0.983 Z-5.592 I-13.9276 K-4.6768
    G03 X1.219 Z-6.157 I-10.6189 K-4.1037
    G03 X1.477 Z-6.691 I-9.0396 K-4.0381
    G03 X1.756 Z-7.193 I-7.947 K-4.0882
    G03 X2.054 Z-7.66 I-6.68 K-3.934
    G03 X2.37 Z-8.09 I-6.4282 K-4.3929
    G03 X2.703 Z-8.48 I-5.8622 K-4.6683
    G03 X3.051 Z-8.829 I-4.2286 K-3.8685
    G03 X3.411 Z-9.135 I-3.2582 K-3.4684
    G03 X3.783 Z-9.397 I-2.9026 K-3.7262
    G03 X4.165 Z-9.613 I-2.2626 K-3.5557
    G03 X4.555 Z-9.781 I-1.7037 K-3.4183
    G03 X4.95 Z-9.903 I-1.2687 K-3.4073
    G03 X5.349 Z-9.976 I-0.8719 K-3.6389
    G03 X5.75 Z-10. I-0.4005 K-3.3303
    Jan 2015
    7
    Hi
    G01 X0. Z0.
    I used the G-Code in the software. The Ellipse curve is fine but there is one final issue - The Ellipse section is reverse. It needs to be rotated by 180 degrees (Clockwise). Can you do me one final favor by rotating it ? I need the ellipse section in the +X,-Z sector (as seen in the image attached by me in previous post)
    Thanks in advance.
    Jul 2003
    1220
    Sorry about that. Give this a try.
    G01 X0 Z0
    G03 X0.024 Z-0.401 I-3.3543 K0.0005
    G03 X0.097 Z-0.8 I-3.7119 K-0.4729
    G03 X0.219 Z-1.195 I-3.5293 K-0.8737
    G03 X0.387 Z-1.585 I-3.5863 K-1.3137
    G03 X0.603 Z-1.967 I-3.7717 K-1.8806
    G03 X0.865 Z-2.339 I-3.9882 K-2.5306
    G03 X1.171 Z-2.699 I-3.7744 K-2.8982
    G03 X1.52 Z-3.047 I-4.2175 K-3.8806
    G03 X1.91 Z-3.38 I-5.0583 K-5.5292
    G03 X2.34 Z-3.696 I-4.8229 K-6.1122
    G03 X2.807 Z-3.994 I-4.401 K-6.382
    G03 X3.309 Z-4.273 I-4.5902 K-7.668
    G03 X3.843 Z-4.531 I-4.5721 K-8.7816
    G03 X4.408 Z-4.767 I-4.6687 K-10.3829
    G03 X5. Z-4.98 I-5.2688 K-13.7146
    G03 X5.616 Z-5.168 I-4.3487 K-13.1457
    G03 X6.254 Z-5.331 I-3.771 K-13.4298
    G03 X6.91 Z-5.469 I-3.7821 K-16.3503
    G03 X7.581 Z-5.579 I-3.254 K-17.7481
    G03 X8.264 Z-5.663 I-2.6274 K-18.5442
    G03 X8.955 Z-5.719 I-1.9051 K-19.216
    G03 X9.651 Z-5.746 I-1.0127 K-17.1213
    G03 X10. Z-5.75 I-0.349 K-15.2231
    Jan 2015
    7
    G01 X0 Z0
    Sorry, I was not clear in my post. Your G-Code is correct but there is a little modification required. The movement in the -Z axis is 10 mm and +X axis is 5.75 mm. When I plot your G-Code, the ellipse curve is reverse. Image attached below -
    Attachment 264220
    The ellipse section needed by me is highlighted by the green box in the image below -
    Thanks in advance.
    Jul 2003
    1220
    I didn't know there could be so many wrong answers.
    I don't know why the curve is the wrong way around.
    You may need to change the I/K positive/negative. (watch first line, I is different to others.)
    Try this version.
    G01 X0. Z0.
    G03 X0.401 Z-0.024 I0.0005 K-3.3543
    G03 X0.8 Z-0.097 I-0.4729 K-3.7119
    G03 X1.195 Z-0.219 I-0.8737 K-3.5293
    G03 X1.585 Z-0.387 I-1.3137 K-3.5863
    G03 X1.967 Z-0.603 I-1.8806 K-3.7717
    G03 X2.339 Z-0.865 I-2.5306 K-3.9882
    G03 X2.699 Z-1.171 I-2.8982 K-3.7744
    G03 X3.047 Z-1.52 I-3.8806 K-4.2175
    G03 X3.38 Z-1.91 I-5.5292 K-5.0583
    G03 X3.696 Z-2.34 I-6.1122 K-4.8229
    G03 X3.994 Z-2.807 I-6.382 K-4.401
    G03 X4.273 Z-3.309 I-7.668 K-4.5902
    G03 X4.531 Z-3.843 I-8.7816 K-4.5721
    G03 X4.767 Z-4.408 I-10.3829 K-4.6687
    G03 X4.98 Z-5. I-13.7146 K-5.2688
    G03 X5.168 Z-5.616 I-13.1457 K-4.3487
    G03 X5.331 Z-6.254 I-13.4298 K-3.771
    G03 X5.469 Z-6.91 I-16.3503 K-3.7821
    G03 X5.579 Z-7.581 I-17.7481 K-3.254
    G03 X5.663 Z-8.264 I-18.5442 K-2.6274
    G03 X5.719 Z-8.955 I-19.216 K-1.9051
    G03 X5.746 Z-9.651 I-17.1213 K-1.0127
    G03 X5.75 Z-10. I-15.2231 K-0.349
    Jan 2009
    104
    You could use line segments for the path and it should look smooth enough.
    Try this:
    G1 Z0 X0.
    Z-0.0015 X0.1004
    Z-0.0061 X0.2007
    Z-0.0137 X0.3009
    Z-0.0244 X0.4011
    Z-0.0381 X0.5011
    Z-0.0548 X0.601
    Z-0.0745 X0.7007
    Z-0.0973 X0.8002
    Z-0.1231 X0.8995
    Z-0.1519 X0.9985
    Z-0.1837 X1.0972
    Z-0.2185 X1.1955
    Z-0.2563 X1.2935
    Z-0.297 X1.3911
    Z-0.3407 X1.4882
    Z-0.3874 X1.5849
    Z-0.437 X1.6811
    Z-0.4894 X1.7768
    Z-0.5448 X1.872
    Z-0.6031 X1.9666
    Z-0.6642 X2.0606
    Z-0.7282 X2.154
    Z-0.795 X2.2467
    Z-0.8645 X2.3387
    Z-0.9369 X2.4301
    Z-1.0121 X2.5206
    Z-1.0899 X2.6104
    Z-1.1705 X2.6995
    Z-1.2538 X2.7877
    Z-1.3397 X2.875
    Z-1.4283 X2.9615
    Z-1.5195 X3.047
    Z-1.6133 X3.1317
    Z-1.7096 X3.2154
    Z-1.8085 X3.2981
    Z-1.9098 X3.3798
    Z-2.0136 X3.4604
    Z-2.1199 X3.5401
    Z-2.2285 X3.6186
    Z-2.3396 X3.696
    Z-2.4529 X3.7723
    Z-2.5686 X3.8475
    Z-2.6865 X3.9215
    Z-2.8066 X3.9943
    Z-2.9289 X4.0659
    Z-3.0534 X4.1362
    Z-3.18 X4.2053
    Z-3.3087 X4.2731
    Z-3.4394 X4.3396
    Z-3.5721 X4.4048
    Z-3.7068 X4.4686
    Z-3.8434 X4.5311
    Z-3.9818 X4.5922
    Z-4.1221 X4.6518
    Z-4.2642 X4.7101
    Z-4.4081 X4.767
    Z-4.5536 X4.8224
    Z-4.7008 X4.8763
    Z-4.8496 X4.9287
    Z-5.0 X4.9796
    Z-5.1519 X5.0291
    Z-5.3053 X5.0769
    Z-5.4601 X5.1233
    Z-5.6163 X5.1681
    Z-5.7738 X5.2113
    Z-5.9326 X5.2529
    Z-6.0927 X5.2929
    Z-6.2539 X5.3313
    Z-6.4163 X5.3681
    Z-6.5798 X5.4032
    Z-6.7443 X5.4367
    Z-6.9098 X5.4686
    Z-7.0763 X5.4988
    Z-7.2436 X5.5273
    Z-7.4118 X5.5541
    Z-7.5808 X5.5792
    Z-7.7505 X5.6026
    Z-7.9209 X5.6243
    Z-8.0919 X5.6444
    Z-8.2635 X5.6626
    Z-8.4357 X5.6792
    Z-8.6083 X5.694
    Z-8.7813 X5.7071
    Z-8.9547 X5.7185
    Z-9.1284 X5.7281
    Z-9.3024 X5.736
    Z-9.4766 X5.7421
    Z-9.651 X5.7465
    Z-9.8255 X5.7491
    Z-10.0 X5.75
    code is for x(radius) not diameter.
    Jan 2009
    104
    The above code will only cut accurately with a sharp tool
    this path is for using a 1.25mm corner rad.
    (1.25 CORNER RAD. INSERT)
    G1X-0.394Z0.
    X-0.2875Z-.002
    X-0.175Z-.007
    X-0.0625Z-.015
    X0.0495Z-.027
    X0.161Z-.043
    X0.273Z-.061
    X0.384Z-.083
    X0.495Z-.109
    X0.6055Z-.137
    X0.7155Z-.169
    X0.8255Z-.205
    X0.934Z-.243
    X1.0425Z-.285
    X1.15Z-.33
    X1.2575Z-.378
    X1.3635Z-.429
    X1.469Z-.484
    X1.5735Z-.541
    X1.6775Z-.602
    X1.7805Z-.665
    X1.8825Z-.731
    X1.984Z-.801
    X2.084Z-.873
    X2.1835Z-.948
    X2.282Z-1.026
    X2.3795Z-1.107
    X2.4755Z-1.19
    X2.571Z-1.277
    X2.6655Z-1.366
    X2.7585Z-1.457
    X2.8505Z-1.552
    X2.9415Z-1.649
    X3.031Z-1.748
    X3.12Z-1.85
    X3.207Z-1.955
    X3.2935Z-2.062
    X3.3785Z-2.171
    X3.462Z-2.283
    X3.545Z-2.397
    X3.626Z-2.514
    X3.706Z-2.632
    X3.7845Z-2.753
    X3.862Z-2.876
    X3.938Z-3.002
    X4.0125Z-3.13
    X4.086Z-3.259
    X4.158Z-3.391
    X4.2285Z-3.525
    X4.2975Z-3.66
    X4.365Z-3.798
    X4.431Z-3.938
    X4.496Z-4.079
    X4.5595Z-4.223
    X4.621Z-4.368
    X4.681Z-4.515
    X4.74Z-4.663
    X4.797Z-4.814
    X4.853Z-4.966
    X4.907Z-5.119
    X4.959Z-5.274
    X5.01Z-5.43
    X5.0595Z-5.588
    X5.107Z-5.748
    X5.153Z-5.908
    X5.1975Z-6.07
    X5.2405Z-6.233
    X5.2815Z-6.398
    X5.321Z-6.563
    X5.3585Z-6.73
    X5.3945Z-6.898
    X5.429Z-7.067
    X5.462Z-7.236
    X5.493Z-7.407
    X5.522Z-7.579
    X5.5495Z-7.751
    X5.575Z-7.924
    X5.599Z-8.098
    X5.6215Z-8.272
    X5.642Z-8.447
    X5.6605Z-8.623
    X5.6775Z-8.799
    X5.6925Z-8.976
    X5.706Z-9.153
    X5.718Z-9.331
    X5.7275Z-9.508
    X5.7355Z-9.686
    X5.742Z-9.865
    X5.7465Z-10.043
    X5.749Z-10.221
    X5.75Z-10.398
    hope that helps
    Jan 2015
    7
    Quote Originally Posted by mcode View Post
    Try this:
    G1 Z0 X0.
    Z-0.0015 X0.1004
    Z-0.0061 X0.2007
    Z-0.0137 X0.3009
    Z-0.0244 X0.4011
    Z-0.0381 X0.5011
    Z-0.0548 X0.601
    Z-0.0745 X0.7007
    Z-0.0973 X0.8002
    Z-0.1231 X0.8995
    Z-0.1519 X0.9985
    Z-0.1837 X1.0972
    Z-0.2185 X1.1955
    Z-0.2563 X1.2935
    Z-0.297 X1.3911
    Z-0.3407 X1.4882
    Z-0.3874 X1.5849
    Z-0.437 X1.6811
    Z-0.4894 X1.7768
    Z-0.5448 X1.872
    Z-0.6031 X1.9666
    Z-0.6642 X2.0606
    Z-0.7282 X2.154
    Z-0.795 X2.2467
    Z-0.8645 X2.3387
    Z-0.9369 X2.4301
    Z-1.0121 X2.5206
    Z-1.0899 X2.6104
    Z-1.1705 X2.6995
    Z-1.2538 X2.7877
    Z-1.3397 X2.875
    Z-1.4283 X2.9615
    Z-1.5195 X3.047
    Z-1.6133 X3.1317
    Z-1.7096 X3.2154
    Z-1.8085 X3.2981
    Z-1.9098 X3.3798
    Z-2.0136 X3.4604
    Z-2.1199 X3.5401
    Z-2.2285 X3.6186
    Z-2.3396 X3.696
    Z-2.4529 X3.7723
    Z-2.5686 X3.8475
    Z-2.6865 X3.9215
    Z-2.8066 X3.9943
    Z-2.9289 X4.0659
    Z-3.0534 X4.1362
    Z-3.18 X4.2053
    Z-3.3087 X4.2731
    Z-3.4394 X4.3396
    Z-3.5721 X4.4048
    Z-3.7068 X4.4686
    Z-3.8434 X4.5311
    Z-3.9818 X4.5922
    Z-4.1221 X4.6518
    Z-4.2642 X4.7101
    Z-4.4081 X4.767
    Z-4.5536 X4.8224
    Z-4.7008 X4.8763
    Z-4.8496 X4.9287
    Z-5.0 X4.9796
    Z-5.1519 X5.0291
    Z-5.3053 X5.0769
    Z-5.4601 X5.1233
    Z-5.6163 X5.1681
    Z-5.7738 X5.2113
    Z-5.9326 X5.2529
    Z-6.0927 X5.2929
    Z-6.2539 X5.3313
    Z-6.4163 X5.3681
    Z-6.5798 X5.4032
    Z-6.7443 X5.4367
    Z-6.9098 X5.4686
    Z-7.0763 X5.4988
    Z-7.2436 X5.5273
    Z-7.4118 X5.5541
    Z-7.5808 X5.5792
    Z-7.7505 X5.6026
    Z-7.9209 X5.6243
    Z-8.0919 X5.6444
    Z-8.2635 X5.6626
    Z-8.4357 X5.6792
    Z-8.6083 X5.694
    Z-8.7813 X5.7071
    Z-8.9547 X5.7185
    Z-9.1284 X5.7281
    Z-9.3024 X5.736
    Z-9.4766 X5.7421
    Z-9.651 X5.7465
    Z-9.8255 X5.7491
    Z-10.0 X5.75
    Hello,
    Thanks for the G-Code. Can you re-send the same suitable for diameter of 11.5 mm as the CNC Lathe operator accepts diameter only and does not know how to key in radius.
    Thanks in advance.
    Jan 2009
    104
    Here ya go
    G1 Z0 X0
    Z-0.0015 X0.2008
    Z-0.0061 X0.4014
    Z-0.0137 X0.6018
    Z-0.0244 X0.8022
    Z-0.0381 X1.0022
    Z-0.0548 X1.202
    Z-0.0745 X1.4014
    Z-0.0973 X1.6004
    Z-0.1231 X1.799
    Z-0.1519 X1.997
    Z-0.1837 X2.1944
    Z-0.2185 X2.391
    Z-0.2563 X2.587
    Z-0.297 X2.7822
    Z-0.3407 X2.9764
    Z-0.3874 X3.1698
    Z-0.437 X3.3622
    Z-0.4894 X3.5536
    Z-0.5448 X3.744
    Z-0.6031 X3.9332
    Z-0.6642 X4.1212
    Z-0.7282 X4.308
    Z-0.795 X4.4934
    Z-0.8645 X4.6774
    Z-0.9369 X4.8602
    Z-1.0121 X5.0412
    Z-1.0899 X5.2208
    Z-1.1705 X5.399
    Z-1.2538 X5.5754
    Z-1.3397 X5.75
    Z-1.4283 X5.923
    Z-1.5195 X6.094
    Z-1.6133 X6.2634
    Z-1.7096 X6.4308
    Z-1.8085 X6.5962
    Z-1.9098 X6.7596
    Z-2.0136 X6.9208
    Z-2.1199 X7.0802
    Z-2.2285 X7.2372
    Z-2.3396 X7.392
    Z-2.4529 X7.5446
    Z-2.5686 X7.695
    Z-2.6865 X7.843
    Z-2.8066 X7.9886
    Z-2.9289 X8.1318
    Z-3.0534 X8.2724
    Z-3.18 X8.4106
    Z-3.3087 X8.5462
    Z-3.4394 X8.6792
    Z-3.5721 X8.8096
    Z-3.7068 X8.9372
    Z-3.8434 X9.0622
    Z-3.9818 X9.1844
    Z-4.1221 X9.3036
    Z-4.2642 X9.4202
    Z-4.4081 X9.534
    Z-4.5536 X9.6448
    Z-4.7008 X9.7526
    Z-4.8496 X9.8574
    Z-5.0 X9.9592
    Z-5.1519 X10.0582
    Z-5.3053 X10.1538
    Z-5.4601 X10.2466
    Z-5.6163 X10.3362
    Z-5.7738 X10.4226
    Z-5.9326 X10.5058
    Z-6.0927 X10.5858
    Z-6.2539 X10.6626
    Z-6.4163 X10.7362
    Z-6.5798 X10.8064
    Z-6.7443 X10.8734
    Z-6.9098 X10.9372
    Z-7.0763 X10.9976
    Z-7.2436 X11.0546
    Z-7.4118 X11.1082
    Z-7.5808 X11.1584
    Z-7.7505 X11.2052
    Z-7.9209 X11.2486
    Z-8.0919 X11.2888
    Z-8.2635 X11.3252
    Z-8.4357 X11.3584
    Z-8.6083 X11.388
    Z-8.7813 X11.4142
    Z-8.9547 X11.437
    Z-9.1284 X11.4562
    Z-9.3024 X11.472
    Z-9.4766 X11.4842
    Z-9.651 X11.493
    Z-9.8255 X11.4982
    Z-10.0 X11.5
    Jan 2015
    7
    Should the code be from X-5.75. to X+5.75 while catering to the diameter ?
    (I have no knowledge in CNC Lathe )
    Can you let me know the software being used to generate the G-Code ?
    Thanks in advance.
Page 1 of 2 12
  1. Arc Interpolation
    By QueueJr in forum Rhinocam
    Last Post: 03-21-2014, 07:07 PM
  2. Creating elliptical surfaces/toolpaths
    By BaxterB in forum Mastercam
    Last Post: 09-13-2012, 03:07 AM
  3. Beveled Kerf and Elliptical Circles
    By Shanghyd in forum Waterjet General Topics
    Last Post: 03-12-2010, 07:27 PM
  4. machining elliptical punch and die
    By ikneb in forum G-Code Programing
    Last Post: 07-17-2009, 02:09 PM
  5. interpolation
    By rimcanyon in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 07:10 AM
