587,743 active members*
3,036 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6560 and stepper 57BYGH633 (current settings?)
    Mar 2013
    I have board TB6560 and stepper motors NEMA23 - 57BYGH633, connected and working.
    My question is:
    This motors are 3A and I don't know if I should leave current setting on board (75%) like it have came shipped or I should change it to 100%?
    Motors are tried with 75% and working, but if they are 3A should I change settings to 100% to have more power?
    Thank you.
    Jul 2013
    Re: TB6560 and stepper 57BYGH633 (current settings?)
    I know this isn't an answer to your question but I've been scouring this site and others on how to get my setup running. Your steppers are 6-wire so how do you have them connected. I've looked at the setup sheet for my controller and data on the steppers and I can't get anything to work. Any help you can provide is greatly appreciated.
    1695
    To connect a 6 wire unipolar stepper to a 4 pin controller, use the center lead and one of the outer ones from the same phase. This is known as the "half coil" configuration.
    Aug 2015
    10
    About the 6-wire,there are 2 ways to connect themne is high torque and the other is high speed.it is according to your requirements on machine.
    For example:
    longs motor 23HS8630 6-WIRES.
    High torque: BLK A+,GRN A-,RED B+,BLU B-,leave others alone.
    High speed: BLK A+,YEL A-,RED B+,WHT B-; YEL A+,GRN A-,WHT B+,BLU B-
    You can try it later.:-)
    Any questions,you can send email to us: [email protected]
  1. Stepper motor compare 57BYGH633 vs 23HS8610
    By Graphicman in forum Want To Buy...Need help!
    Last Post: 01-23-2016, 08:34 PM
  2. TB6560 working, need settings help...
    By d3ath101 in forum Stepper Motors / Drives
    Last Post: 04-14-2014, 10:17 PM
  3. TB6560 decay and current settings. help
    By crimar in forum CNC Machine Related Electronics
    Last Post: 01-21-2014, 04:45 PM
  4. 3rd generation tb6560 board burned up or incorect current settings???
    By austinblake92 in forum CNC Wood Router Project Log
    Last Post: 09-19-2013, 04:12 AM
  5. Stepper Driver Settings (Microstep and Current)
    By maximusalto in forum Stepper Motors / Drives
    Last Post: 03-09-2013, 04:59 AM
