587,613 active members*
3,121 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > "rotate tool drum first" probelm Fanuc OMC
Results 1 to 12 of 12
    Mar 2019
    58
    after making homing
    this msg appear "rotate tool drum first"
    any help
    Re: "rotate tool drum first" probelm Fanuc OMC
    Quote Originally Posted by yurirevenge View Post
    after making homing
    any help
    The tool bank may has some problem, you can check the ATC.
    after making homing
    any help
    Fanuc is a Motion Controller, not an ATC controller. The MTB does that. It might help if people new what Year, Make and Model of machine you're talking about and what type of tool changer it has. Seriously... give only a little, and get back even less.
    Mar 2019
    58
    Quote Originally Posted by the_gentlegiant View Post
    i need the param to put tool in magazine and tool in spindle Fanuc Omc , cincinnati milacron sabre 1000
    Mar 2019
    58
    any one can help.
    am trying to remove motor of magazine and it is not running may broken from 4 years , and the machine was working normally .
    now i need to change parameter or diable tool magazine to delete this error ( Rotate tool drum first)
    Mar 2019
    58
    Mar 2019
    58
    after making homing
    any help
    Dec 2008
    3128
    Do you expect anyone to diagnose an issue with your car, if you tell them "there's some noise under the hood, and a light on the dash" ?
    Mar 2019
    58
    after making homing
    any help
    Dec 2008
    3128
    Be insulting... it's your loss
    You need to sit back and look at what minimum info you need to give.... what one machine manufacturer with Fanuc control, more than likely, is going to be different to another maker.
    But again... your loss
    Mar 2019
    58
    after making homing
    any help
    Apr 2019
    146
    Please remain polite and follow netiquette. thanks
    Community Manager <a href="https://de.industryarena.com/" target="_blank">https://de.industryarena.com/</a>
