587,700 active members*
3,411 visitors online*
Results 1 to 8 of 8
    Feb 2007
    48
    LazyCAM entities
    Does anyone know if LazyCAM will recognize spline entities as generated by AutoCAD? I can import the image and it will actually select the spline as a chain, but I can not pocket up to it.
    Please advise.
    May 2005
    1810
    Save the output from Acad as a R-12 DXF and see what happens.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Feb 2007
    48
    No change...I read on the Mach site that splines are a problem for LCAM for now. I use them alot for doing manual bitmap traces, etc. Is there a better software for doing these types of raster to vector conversions without breaking the bank?
    May 2005
    1810
    Splines are trouble for most affordable CAM packages. If you save your DXF as an R-12 DXF, it will convert your splines to simple polylines and any CAM package will then process them without a hitch.
    Give it a try.
    Scott
    Feb 2007
    48
    ...still no luck.
    May 2005
    1810
    Can you post the offensive file?
    Scott
    Feb 2007
    48
    This is not the original, but this is significantly more simple than the original and I still can't seem to get it to work as an R12 .dxf. I am just trying to pocket out inside the ellipse and island the irregular shape(s) on the inside.
    Attached Files Attached Files
    LazyCAM is probably having trouble due to all the very small segments. Probably not much you can do.
  1. Need help with lazycam
    By jeffg in forum Mach Mill
    Last Post: 05-31-2007, 05:43 PM
  2. Click On Drawn Entities
    By TURNER in forum Visual Basic
    Last Post: 05-17-2007, 04:41 PM
  3. Lazycam
    By dan dimock in forum Mach Software (ArtSoft software)
    Last Post: 04-15-2007, 01:44 PM
  4. Newbie, No entities found
    By Shepard in forum Solidworks
    Last Post: 04-13-2007, 06:21 AM
  5. LazyCam
    By randyf1965 in forum Mach Software (ArtSoft software)
    Last Post: 04-18-2006, 04:29 PM
