587,466 active members*
3,265 visitors online*
    Jun 2020
    Unhappy Very much on the side of confused...
    Hello everybody i hope all is well, Let me just briefly explain my situation, im currently doing an internship at a plastic manufacturing company and they have many HAAS machines and im well able to use them, but they recently purchased a doosan Puma 280LM with a Fanuc oi -TC controller, so far i have been able to send jobs too it over Ethernet (I created a virtual com port)
    ANYWAYS My question is very ambiguous all im trying to do is start the job and setup tool changing but im LOST, when i try starting it it says IMPERFECT WORD must be changed..... Any help would be fantastic, and also have no clue about the tool calibrator, when i push it down it just goes backup...
    Apr 2004
    5747
    Re: Very much on the side of confused...
    If you look on page 17 of this manual https://virag-hightechcnc.hu/uploads...MCP03ER002.pdf , it talks about that, but unfortunately it's in Chinglish so figuring out what exactly you need to do might take a little trial and error.
    Andrew Werby
    Website
    Jan 2018
    1516
    Quote Originally Posted by awerby View Post
    Everthing is frikkin Chinese. We buy all there stuff, grow there power, lose our own manufacturing & skills.
    They return the favour by infecting the world from there trampy, dirty, disgusting, hovel suburbs.
    Things need to change.
    1234
    Quote Originally Posted by jeffersonpaul View Post
    I don't know anything about your specific machine,but then neither does the OP........Regarding the IMPERFECT WORD display it may just be that the controller is case sensitive-have you seen anything to make you believe that lower case will work?The other thing that occurs to me is that you may need to check that the program you create has been through the correct post processor for the Fanuc controller.If you use the post for the Haas it may not produce a program that is compatible with the Fanuc syntax.Well done for using the network for file transfer,its the logical thing to do.
