587,192 active members*
2,245 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > Semi - DIY CNC Router / Mill Project Build (With photos)
Results 1 to 18 of 18
    I have a metal fabrication business and have been wanting to get a CNC router / Mill for a long time. I have been doing research for a few months and spent sometime at a few trade shows looking everything over. I have a lot to learn when it comes to routers and mills, just a little different from plasma.
    I decided to start out with a small bench top system and build it up as sort of a DIY project and see how it works and maybe expand to a larger table down the road.
    My goal is to make this a multi-purpose machine if I can. I want to be able to make signs out of wood and plexi, machine parts out of aluminum, cut sheet goods like vinyl and cardboard for prototypes, and if I can attach an extruder and make a 3d printer out of the same machine....
    So here goes I have been buying components as time and money allows and finally have enough to get started. I though I would post the build here and hopefully get some good advice along the way and share my trials and tribulations as I go.
    So day one got the table from Precision Plasma assembled it and attached the Porter cable 7310 router. I'm waiting on my steppers and controller which I hope will be delivered soon.
    Desert Fabworks LLC -Fort Mohave, Arizona
    www.desertfabworks.com - Project Sites: www.cncplasmabuild.com - www.cncrouterbuild.com
    Apr 2007
    8082
    Starting with a small kit before embarking on a large DIY machine is a good idea. It lets you learn the software side of it while you are making drawings, accumulating materials and building the larger machine. Even after completing the large machine you will likely keep and continue to use the small machine for things it can do better.
    You could even decide that this is just not for you if you just don't have the time or the interest to dedicate to it. The big machine just gives you room to create larger projects. It doesn't really do anything different otherwise.
    Check out Widgetmaster's 5' x 9' build log. I'm also getting parts ready to rebuild my 5' x 12' machine's frame using larger steel box tubing. There are other steel and aluminum machine build logs on this site to get ideas from. The MechMate plans are popular for building a steel machine without designing one.
    CarveOne
    Got the Controller package and stepper motors in from CandCNC yesterday. I went with the BladeRunner Package. Its the same package I use on my CNC Plasma System and it has worked very well. About the only difference is that this one does not have torch height control.
    The steppers are 300 oz - The router has a 2TPI screw for x and y, so the steps per inch is 4000. I use 50 for acceleration and can go 200 ipm or faster. The Z is 5 tpi, so the steps per inch is 10000. Acceleration 50 and velocity 100 or faster. With this setup I will have about 175 lb of cutting force on X and Y.
    I was not expecting the steppers to be double shaft steppers. My plasma machine uses single shaft steppers. I did some reading online and from what I read no real difference some people suggested adding a thumb knob on the end to allow for some fine adjustment when the power is off.?
    The case has two built in Aux power outlets. I will use one to plug my router into so that I can control it via the computer and the Mach3 interface.
    This weekend I plan on installing the software from CandCNC as well as Mach3 and Sheetcam, getting everything plugged in and do some test movements to make sure the basics are working.
    Attached Thumbnails Attached Thumbnails router_controler.jpg   cnc_controler_power.jpg   cnc_controler_axis_connections.jpg   inside_cnc_controlelr.jpg
    I have been slacking on updating the build progress. Had to squeeze in a little vacation while I could.
    I was able to get all of the software installed and do some basic motion testing and configuration. I installed Mach3 for my machine control software which has custom screens from the bladerunner package. I also installed Sheetcam for 2d work. I use it all the time for plasma cutting so I though I would put it on this system since I'm familiar.
    I also installed Aspire and Photo V Carve from Vectric which I plan to use for most of the routing and carving.
    Program install was easy no problems. Powered up the the machine and was able to move it around the table using Mach3 No cutting yet.
    Anyone have another programs they think I should have or could use. I want to eventually add a rotary axis. I'm still reading up on aspire and getting familiar with all it can do.
    Next project is adding the home and limit switches along with some cable management to the machine.
    Apr 2007
    8082
    Check out the Monthly Projects section of the Vectric site for some projects to get you started. Watch the tutorials on the Aspire CDs or on the Vectric site. The Vectric user forum has been very useful for ideas and get questions answered.
    My two build logs in this forum has lots of photos of things I've made with Vcarve Pro or Aspire. My website has some free downloads you might be interested in.
    Have fun with your machine.
    CarveOne
    Jan 2006
    156
    Am I mistaken or are the correct number of steps for 2TPI 400 and 5TPI 1000.
    Quote Originally Posted by CarveOne View Post
    Thanks! I appreciate the info I will check that out. I really appreciate the tips, tricks, and info that I'm getting from the other people in the forum. I have lots to learn when it comes to using this machine. I have started watching the tutorials on the vectric site which is helping.
    Quote Originally Posted by salzburg View Post
    I set it up with 2/400 and 5/1000 I used a micrometer to verify the x and y but did not check the z I will check that
    I got most of the cable management done with the Igus track I got of ebay and I mounted the Air system for the blow off nozzles for clearing the cut path. I plan on just plugging the system into the shop air and regulate it with the on off valve.
    Had a few people suggest the nozzle system for doing aluminum. I don't plan on running any type of coolant system. I would like to keep it all dry if I can.
    Its nice having the plasma machine in the shop. I needed some custom brackets and supports to mount things so a quick drawing threw some aluminum on the plasma table and made some bends and I had come custom brackets.
    Next project in this build was to start building the cart that all this will mount to and on. My shop never has enough room so I have to keep this project mobile.
    Attached Thumbnails Attached Thumbnails bulldog_cnc_router_airline.jpg   plasma_cut_alu_brackets.jpg
    Apr 2009
    5516
    Looks great! I do not use an air nozzle for aluminum; rather I brush on WD-40 or other lubricant. You don't need much, but I find when slotting it helps to brush some in the kerf as the router moves along. If you get shiny, smooth surfaces you're doing it right. If the surfaces are gray and dull, usually not so... I also find cast tooling plate to work best, though others say it gums up.
    I double checked all of the settings and for the X Y and Z and the steps everything is setup and working correctly it is : The Z is 5 tpi, so the steps per inch is 10000
    When I built up my plasma cutting system I built a custom cart / control center for it. I wanted to do the same for this project. Space in my shop is very limited so I wanted to put the entire machine and all of its components on a single cart and keep the entire project self contained and mobile.
    I think this is one of the fun-est parts of the project building and designing. When I'm done I hope to have the computer, Bladerunner Control box, vacuum hold down system and vacuum dust recovery system all built into the cart.
    The first couple of pictures is of the cart that I built for my plasma system. It folds closed and rolls neatly under the plasma table. Then opens up with gas assist shocks to expose the entire control center.
    If anyone has built something like this for their router / mill I would love to see it and get some ideas.
    Attached Thumbnails Attached Thumbnails desert-fabworks-computer-cart-plasma.jpg   finished-plasma-computer-cart.jpg
    After a lot of mock ups planning and measuring I finally came up with a plan for the Cart/Control center that will hold this router and all of the components. The cart will be 26" wide x 44" Long x 36" tall.
    The router will mount on the top of the cart and inside of the cart I will house the Computer, monitor, keyboard and Mouse, Blade Runner Control box, UPS power supply,
    Vacuum System, Vacuum Hold down system, and all the accessories that go along with it.
    If everything works out like I have planned this will be a very cool cart. The whole thing will be on wheels to allow it to easily move around the shop and out of the way when not in use. Because I do more welding than woodwork I decided to build the cart out of steel. I'm using 1x2 tube for the base and top frame, and 1in square tube for the internal supports. All of this will support a 1/4 steel plate top that the router will mount on.
    Here are a couple of pictures there are quite a few more on the build site photo gallery = BUILD PAGE 8
    Attached Thumbnails Attached Thumbnails IMG_2281.jpg   IMG_2292.jpg   IMG_2303.jpg
    Here are the latest picture updates from the cart build. Have not had enough time o dedicate to this project too many other things going on. Slow going at the moment.
    I figured out my fold up monitor system and finalized the locations of some of the equipment in the cart.
    Here is a link to more pics on the build page: BUILD PAGE 9
    Jan 2011
    24
    Good construction setup
    Life got way too busy during the holidays and got behind on this project. I was able to get the cart finished. I cut a custom front door panel with the BullDog router logo on the front of the door.
    Everything is back from powder coating just putting the finishing touches on everything and getting all of the cables and controls run.
    Hope to be cutting and making things soon. The cart / control center for this project really came out nice.
    I hope to have pictures and a video of the completed cart / control center up next week. Here are the latest pictures till then. I have some more pictures on the build website: BUILD PAGE 10
    Attached Thumbnails Attached Thumbnails IMG_2325.jpg   IMG_2345.jpg   IMG_2353.jpg   IMG_2351.jpg
    The CNC Router Cart is finally finished! I was able to get everything mounted and all of the wiring routed, hooked up and get all of the components functioning. Now I get to start cutting.
    The monitor gas shock system to flip the monitor up and hold it in place came out great. a little hard to grasp in a picture should have a video soon. I had some red led's laying around and decided to hook them up and place them round the stainless steel insert panels and wire them to a small 12 volt battery.
    With a flip of the switch the front panel glows red. Not very practical but looks cool.
    I used pVC pipe to route the shop vac line up to the table and have a fitting on the top of the table for the hose to hook into and then attach to the dust boot that will go on the router.
    I also ran the vacuum system line up to the top of the table with an on off valve and a gauge for controlling the suction to the hold down pods.
    I started working on vacuum hold down table design that I saw on Donek tools, that will mount to the bed and be used for holding down pieces when cutting with the drag knife.
    I hope to get the video edited and have it up soon but for now here are some pictures of the completed cart and the start of the vacuum hold down table.
    BUILD PAGE 14
    Attached Thumbnails Attached Thumbnails finished_router_cart_front.jpg   20131102_180030_renamed_28462.jpg   20131102_180218_renamed_12101.jpg   vacuum_holddown_fixture.jpg
    Re: Semi - DIY CNC Router / Mill Project Build (With photos)
    Its been awhile since I updated this post but here is some new stuff. I upgraded my Bladerunner controller to the new Ethercut system from Candcnc. This gets rid of the parallel and serial ports and runs everything on one ethernet cat5 connection from the computer.
    At the same time I upgraded the computer from xp to windows 7. This was a really nice upgrade the speed increase and reliability increase were huge. This new system also kind of future proofs the system because you do not find new computers coming out with serial and parallel ports nor is xp supported anymore.
    I also added a laser cutter to the gantry. I have wanted this machine to do many things and kind of be a multipurpose machine. This laser is pretty cool. So I can use the router to cut or engrave something and then have the laser come back and mark the piece or I can use the laser to do the cuts.
    Here is a link to the info on the Ethercut upgrade: BUILD PAGE 16
    Here is a video of the laser setup https://www.youtube.com/watch?v=WPjHpUH9Zic
  1. 5AXIS: photos - new build
    By markcomp77 in forum DIY CNC Router Table Machines
    Last Post: 02-24-2018, 06:33 PM
  2. My CNC build-up with video and photos + everything a beginner should know
    By dmoore in forum DIY CNC Router Table Machines
    Last Post: 02-07-2008, 02:53 AM
  3. Help me decide -- MTC Semi-Pro or Ez-Router
    By Hyrum R in forum Commercial CNC Wood Routers
    Last Post: 04-24-2007, 12:46 AM
  4. Higher End Large Format Router Mill Project
    By jsage in forum Open Source CNC Machine Designs
    Last Post: 02-24-2007, 04:58 PM
  5. 3X3 Gantry router/mill project
    By Bloy2004 in forum CNC Wood Router Project Log
    Last Post: 03-12-2006, 06:07 AM
