587,419 active members*
3,086 visitors online*
    Jan 2014
    Heidenhain TNC 124 service manual needed
    Gentlemen,
    I am trying to repair an old TNC 124 control unit. It powers up with a overheat error.
    Somebody replaced the fan under the control PCB (perhaps maintenance) and did not fix the problem.
    I am looking for the thermal measuring circuit.
    Thank You
    Jan 2014
    I was able to repair this unit, the repair folks at Heidenhain explained that the unit was no longer repairable, but gave me a few tips, It came down to the power supply for the regulated -12 volt and -15 volt missing the supply B+. There are (3) 470 uf caps that leaked slightly on the PCB, and cause enough corrision to disconnect the supply from both regulators.
    Dec 2017
    Re: Heidenhain TNC 124 service manual needed
    Gentlemen,
    Thank You
    Aug 2010
    5
    Quote Originally Posted by MarcoCabezas View Post
    Gentlemen,
    Thank You
    Hi Marco
    I’m also looking for the service manual and the software PLC.exe and PLCmon.exe for the TNC 124.
    Did you have any luck.
    Please share the link if possible.
    Thanks.
  1. Schematic / service manual needed for Sugino Self Center V8
    By lion_rapid in forum Machinery Manuals / Brochures
    Last Post: 10-22-2012, 07:32 PM
  2. CNC Turret Punch Press Machine: Aquilla 1250 service manual needed
    By jelajahborneo in forum Machinery Manuals / Brochures
    Last Post: 10-11-2012, 08:33 AM
  3. Heidenhain TNC 407 service/repair
    By Finnur in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2010, 10:09 AM
  4. Fanuc service manual(s) needed!
    By Die61 in forum EDM Discussion General Topics
    Last Post: 10-25-2010, 03:09 AM
  5. Service manual needed DWC200
    By tcforge in forum EDM Discussion General Topics
    Last Post: 01-21-2009, 06:15 PM
