587,089 active members*
2,923 visitors online*
    Apr 2005
    40
    Question NO movement, Any suggestions for my gecko 201 and Mach3 setup?
    I have a Camtronics controller with gecko 201 controls, purchased used from a working setup that was retro-fitted. The motors and control all seam fine, I hooked the cables to the motors on my CNC router. I turned on the control and the motors are holding position ok, but can't seam to get them to move. I setup the direction pin settings and set it to active low on in mach3. I'm not sure what to do next with setting up mach3 in the software and testing the motors. Any help or links would be appreciated.
    Thanks in advance!
    Get a multimeter, set it to DC volts, put the black lead on your breakout board ground (GND) and the red lead to the G201's DIRECTION terminal. Jog the axis CW, jot down the voltage. Jog the axis CCW, jot down the voltage again. One reading must be under 0.5V, the other reading must be above 4.5V. If not, your breakout board is not powered, there is no connection to the G201 or you are not porting Mach3 to the correct axis.
    Mariss
  1. Mach3 Gecko 201
    By Ed Williams in forum Gecko Drives
    Last Post: 08-20-2008, 06:16 AM
  2. Need suggestions on a 9'x5.5' setup -screws and slides
    By turbotoys in forum DIY CNC Router Table Machines
    Last Post: 09-05-2007, 03:24 AM
  3. First Gecko setup
    By Soundstorm in forum Gecko Drives
    Last Post: 02-15-2007, 11:21 AM
  4. my long new machine setup . suggestions please
    By max_imum2000 in forum CNC Machining Centers
    Last Post: 12-29-2006, 07:04 PM
  5. gecko CNC setup
    By jarr88 in forum Gecko Drives
    Last Post: 06-17-2006, 08:52 PM
