587,421 active members*
3,239 visitors online*
IndustryArena Forum > CAM Software > CamBam > Toolpath calculation bug?
    Hello,
    I am not sure why Cambam calculats for my pocket operation not the right toolpath.
    The problem is that i want to cut a pocket with a 6mm diameter tool. When i choose a step over of 0.6 Cambam generates a toolpath that
    did not cut the whole "middle". Between two pathes there are 6.88mm distance ...
    I will give you three examples:
    0.6 step over (distance between the two lines in the middle is 6.88mm)
    Attachment 268894
    0.5 step over (distance between the two lines in the middle is ~2mm)
    Attachment 268898
    0.7 step over (distance between the two lines in the middle is 5.54mm)
    Attachment 268896
    So my question is: Why does Cambam does not add a toolpath in the middle like it does for step over 0.5? 6mm tool and 6.88mm distance between pathes?
    Thank you!
    Nov 2008
    643
    Re: Toolpath calculation bug?
    The first tooth path is the cutter radius away from the wall. Then each successive cut is taken at Stepover * cutter diameter in from the last cut until there is no room left to step. So a step over of .5 would mean the cutter moves in 3mm. I haven't gone thru all the combinations but I don't think there is a step size that would result in leftover material in the center (a gap of >cutter radius).
  1. Calculation
    By Rajeshwari in forum Machinery Manuals / Brochures
    Last Post: 07-01-2012, 11:08 AM
  2. Need some calculation help
    By Milton in forum Automation Technology Products
    Last Post: 07-01-2011, 08:20 PM
  3. Super slow toolpath calculation V23
    By Born2l8 in forum BobCad-Cam
    Last Post: 12-16-2010, 07:45 PM
  4. NC- Calculation, help please :)
    By Snajder in forum Mechanical Calculations/Engineering Design
    Last Post: 04-23-2010, 05:11 AM
  5. calculation
    By biotec in forum Stepper Motors / Drives
    Last Post: 04-20-2009, 07:26 AM
