587,616 active members*
3,442 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > adding a tool to the Library
    Jul 2008
    11
    I use tapered ball cutters for wood carving and there is no tapered ball in the library. How can I add a tapered ball to the tool library?
    the tool is as follows:
    Application Data (tool description for CAM software)
    Shank Diameter = 0.250"
    Half angle = 5.13° (0.0625" tip)
    Tip radius = nominal ±0.001"
    Stepdown = Depth per Pass, use 0.250" for roughing and 0.010" for final cleanup)
    Depth of Cut (DOC) = 1.074"
    Stepover (for final cleanup pass) = 0.006"
    Stepover (for roughing pass) = 0.025"
    Spindle RPM (SPEED) = 5 KRPM to 60 KRPM
    Feedrate (IPM) = Depends on the material being cut. Do the Sweetspot Test before setting this parameter (go to: http://www.precisebits.com/tutorials...s_n_speeds.htm).
    Plunge rate = 10 IPM to 25 IPM (again depending on material being cut)
    Mark
    Jun 2008
    1838
    There isn`t such a tool available right now in BobCAD (Hopefully in the next Build), maybe you could try using a "V-Tool", you won`t be able to do the ball end but you should be able to get your angles.
    Or a "Chamfer Mill", there you can set a small and large diameter and your angles, won`t look right on the simulation but it should produce the right tool path for you.
    Regards
    Rob
    :rainfro::rainfro:
  1. Tool Library
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-26-2011, 08:11 AM
  2. Tool Library into 7
    By R.DesJardin in forum SprutCAM
    Last Post: 03-11-2010, 02:54 PM
  3. Printing tool library
    Last Post: 03-02-2009, 05:24 AM
  4. Tool Library and Tool Menu ?s.
    By Stampede in forum BobCad-Cam
    Last Post: 01-16-2009, 01:56 AM
  5. tool library...or is it?
    By brooklynmetal in forum BobCad-Cam
    Last Post: 06-16-2008, 07:34 PM
