What do you think about this machine?
It took me about 3 weeks to build-it from scratch, but the results are very good. Cnczone was very usefull.
Things left to be done:
- arrange the wires
- mount limit switch and Estop
- update to a 3 axis microstepp driver (i would like to use the new A4983 allegro chips)
- buy a USB CNC controller
- build an automatic speed controler for motor (it is a cheap 220V/115W driller, but is working very well in DC too - so it's easy to control the motor voltage to get different RPM; tought about encoder-PIC-pwm-PowerMOS to set the speed)
You will see the tools i have been used, and the result (2 pcb)
