Originally Posted by
ger21
Note that there are some issues with comp in Mach3 that will be addressed in the next version (4), which is probably still a long way from release, and even longer for a Tormach release. What those issues are I don't know, as I haven't seen them.
That's why Tormach is recommending not to use cutter comp, dollars to donuts.
I have heard a number of reports from different folks that cutter comp is "iffy" in Mach3. I have heard from a number of folks that say it works great. Kinda like this thread, LOL.
From those who've been able to elaborate, the impression I get is that if you do everything exactly the way Mach wants it, it will work most of the time. But, "exactly the way Mach wants it" is supposedly not exactly how the rest of the CNC world operates.
To make things more exciting, the differences are apparently not documented, and there are concerns that if 4.0 "fixes" the differences so that it works like Fanuc et al, then the folks that got it to work will be unhappy as their code quits working.
One step Brian should take is documenting the issues so people know what to do now, and what it will be like later.
Cutter comp is a messy business to build in software (he said while working with it in the G-Wizard G-Code Editor), but it sure is useful to machinists.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
