587,770 active members*
3,087 visitors online*
Results 1 to 20 of 23
    Jul 2012
    Red face Chinese Laser Software Experience?
    Hi CNCzone'
    This is my first post within this forum, so please do excuse me if this question comes up a lot, I have had a quick look but didn't find what I'm looking for.
    First off, I know there are more than a few of you out there that think the eBay availible Chinese K40's are pretty much trash, but iv found quite a few blogs where with some tinkering they can become quite useful hobby tools.
    I'm looking at these eBay listings as examples:
    This is parallel port controlled, but works with the newly drivers
    40W CO2 LASER ENGRAVING CUTTING THIRD GENERATION MODEL MACHINE ENGRAVER o6 | eBay
    This is USB controlled, but uses LaserDRW and WinsealXP. Both of which I cant find much on, but I'm under the impression that they are USB compatible newly driver clones.
    220V USB CO2 40W 300mm/s Laser Engraving Cutting Machine Engraver 300×200mm | eBay
    I havn't bothered with any that use moshiDRAW as iv read that it pretty much kills the limited usability of the machine.
    My question is, has anyone got any experience of these drivers/machines? Specifically the LaserDRAW WinsealXP drivers. But any other experience from owners/users would be much appreciated.
    As for tinkering with things like this, I'm more than happy modifying stuff. I would infact concider making my own from 'common' parts, but at £500-550 it seems uneconomical. As it stands I'd be adding watter chilling unit with flow indicator/alarm, an air assist system, and maybe a few other minor adaptations.
    I should also say that I use many titles, including AutoCAD, inkspace and gimp to generate designs, so the software would be purely used as a driver.
    Thanks for reading this wall of text, and thanks for any help, it will be much appreciated.
    Nov 2008
    382
    Hey there
    first you are damn right this machines are for hobbyist and beginner and can be modified to pretty much professional standart on the size.
    you need to re-do most of the mechanical parts in regards to square it off and put a few more bearings in because they only have one in each idler.
    next you need to replace the electronic parts because the original electronic and software is not reliable.
    i have done quite a few convertion of this machines and even guided a few guys thru the process to do it themself.
    I mean the upgrade sure cost quite a bit of money if I make the arrangements it would be
    1 laser power supply $ 205
    2 stepperdriver $ 40 each $ 80
    1 DSP controller $ 450
    1 24V main power supply $ 30
    shiping and handling around $ 120
    then you would have a system what has the newest software and this are the ones where the machines cost around $ 3000 to 5000
    I have attached a few picture what is done with this machines after conversion.
    if you are interested just send me a PM to [email protected]
    greetings
    walt
    Attached Thumbnails Attached Thumbnails 4golfcart.jpg   6tilepic.jpg   ahug0001.jpg
    Jul 2012
    Thanks Herby,
    The brake down was very interesting. I'm not sure I'd do all at once, I'll most likely space things out as much as it is possible to do. Iv been looking at dsp controllers, but to be honest I'd like to give the native drivers a go first, just to see if I can get anything constructive out of it.
    Iv also found a Chinese page regarding the laserDRW and WinsealXP drivers:
    Google Translate
    It looks like the presumption that these new titles are USB newly clones.
    My main question now is:
    Out of the 3 types of driven machines, which would you recommend?
    Newly comparable (parallel)
    Moshi (USB)
    LaserDRW & WinsealXP (USB)
    I like the idea of USB, not only for the obvious reasons but I also thought that a hub could be fitted in the electronic compartment so the dongle could be internally fitted. But then again the parallel could be converted to USB and could provide Mach communication.
    The other thing ive noticed on the page posted above is that all the boards have crystals wired onto the board, so in therory the speed of cutting could be slowed. Iv seen this done on YouTube, but could it be made to cut faster? Also, on the board marked WinsealXP, there are two crystals, one for cutting? One for engraving? Finally the dates on the boards show that the WinsealXP/laserDRW were printed in 2010/11 so are older than the more upto date Mushi boards.
    Again, any recommendations would be much appreciated.
    Thanks, Steve.
    Nov 2008
    382
    Hi steve
    in any case I recommend the moshi version if this has a moshiboard Version 4.2 with USB because it works with pretty much all types of files like from corewldraw and autocad.
    the moshidraw software and system is a pain in the neck but you could learn to do at least some simple stuff but have to expect that it not allways works like it should and eventually has break downs
    greetings
    walt
    Quote Originally Posted by Smiffy6885 View Post
    Thanks Herby,
    Google Translate
    Moshi (USB)
    Thanks, Steve.
    Jul 2012
    Thanks again Walt for the speedy response.
    You'll have to forgive me if I still go after a little more advice, it's not that I don't trust yours, it's just iv read up on moshi and have found many people complaining about all it's faults (of which there appears to be many). Ive also read that it doesn't plot imported vectors or other graphics well. Something about poor line recognition.
    I'm looking at using the machine to create scale architectural models, so I want to be sure it can translate to some degree of accuracy, although I'm not expecting anything near perfection.
    So if there is anyone else out there who has had experience with these titles and can offer their opinion on what direction I should go, I would be very thankful.
    Steve
    I'm not sure why you would want to buy a pigs ear and try convert it to a silk purse? You can buy a DECENT machine for the amount you gonna spend on those rubbish ones and not have to do any work.
    Jul 2012
    Hi Rodney, I'm not planning on turning it into a silk purse as such. Just some minor changes on a cheap machine to make it more usable. But I'm open to suggestions for alternative machines. But considering that one of these eBay 'pigs ears' is only £515ish to start, (and yes I may eventually change it with a new board etc, but I like to tinker with stuff like this, so that's not a big problem for me) I can't find anything in the same price bracket.
    I take it you have had one?
    You say I can get a decent machine for the same money? Where from? I'm in the UK and would be very interested in a better quality sub £800 machine.
    Those 40w cheapys are absolute rubbish - not worth spending bucks on to make em "better". For around $1700-2200 (probably less than you will spend on the "improved" cheapy after you changed everything) you can actually buy a GOOD machine with excellent software etc that will work properly out the box. Speak to G Weike or Shenui laser about their smaller "good" machines.
    I don't have one of the cheapy's , but know ppl who do and was at the laser factories in China in may last year and saw many work (well barely work and being made. I am not sure why the good laser mnfgrs even offer them for sale , all they are good for is to hurt their reputation.
    Jul 2012
    They do it to offer a solution to meet a price point. They should actually offer a 40w desktop machine with the better electronics and software at a slightly higher price point, I bet that well sell better, and would probably result in follow-up sales when the users outgrow the smaller machine.
    I agree - have spoken to the manufacturers to develop a "western" package , all top of the line electonics and mechanicals , use a GOOD user interface/program , include spares and take more care at mnfgring stage , BUT it's impossible to get through to them on that level cos they are PARANOID about pricing..they think that they will lose sales at a higher price - but it aint so......
    Offering those 40w junkers are like Mercedes including Yugo's in their model range...
    Nov 2008
    382
    Hi Steve
    I got the feeling you want a mercedes fro the price of a fiat.
    the more you ask the more different opinion you would get.
    now if you want to do " scaled architectural models" and make sure that everytime you turn the machine on it comes out exactly as the last time then you need the more expensive models or convert one right a way.
    when you read about moshidraw what combines both newly draw and newly seal it is because the other what you have mentioned just came on the marked and there is not practical experience with this this way nobody can complaine in the different forums and groups.
    just my opinion from the practical stand point.
    greetings
    walt
    Steve
    Nov 2008
    382
    the probleme is that every manufacturer uses parts from others especially in the electronic and software and they wana make money too with big amount
    the result is that any better electronic what is then with a DSP controller and seperat stepper driver and PWM laser powersupply cost then at least 4x as much as the cheapo.
    I have good connections to manufacturer overthere and I know that a machine with the same mechanical parts but the beter electronic cosdt even this much higher price, but I can buy the best parts for not even 25% of the price. dont forgett all the shipping and handling fees plus import taxes what sometimes comes up to evn double the price .
    that means if you can get a cheapo with the feature what I have described from a domestic source you dont have the hassle and the parts for conversion you can some buy at a domestic ebay. this makes the only part what needs to be shiped the DSP what is nothing usually it runs around $50 and the most countrys dont charge taxe if it is send right.
    greetings
    walt
    Quote Originally Posted by atv2 View Post
    Jul 2012
    Hey Guys,
    Thanks for all the advice. As I said before, in not looking to go out of my way to modify anything and I know these machines will always have their limitations.
    The problem for me is that I'm not prepared to spend that kind of many at the moment, although I suppose I could be persuaded.
    The other option open to be is to scratch build a quality machine, but if it's not really going to save money in the end, I'd prefer to just spend a little more.
    Rodney - iv taken look though the manufactures sites that you have recommended and shenhui do seem to offer some interesting items, I'd just be concerned that they would be of the same build and part quality but for a higher price.
    Back to topic tho, which of the bad bunch would people recommend?
    Jul 2012
    Just thought I'd say. Bought a k40 with Moshi draw, it's not perfect but it is workable. In fact as long as you do all your design work in a program like CAD, GIMP or Ink scape, it all works out pretty well.
    Now, as I said these machines and software are not perfect, infant the machine is a little sub par in the quality department, the software is full of bugs and counter intuitive. But with a little practice and technical knowledge they can be very useful tools.
    As to the price, £500 delivered is (at least to my mind) not just cheaper than something like an Epilogue but offers newbies/hobbyists an affordable machine for your workshop/studio.
    Back to the software though. I'm running moshi 2012 on Vista and occasionally when opening, it does load up the mandarin version which then will only shutdown though task manager. But on the most part it has been quite stable, just a bit buggy and a little counter intuitive, not helped by the 'iffy' English translation. But it can when used properly, produce some cool stuff.
    Hope this helps anyone looking at purchasing one of these machines.
    Sep 2012
    55
    Hi Smiffy
    I too am considering buying a £500 machine very similar to yours, with a view to swapping the electronics for a simple stepper motor control board and controlling it all using LinuxCNC via the parallel port.
    Do you think that the mechanics/laser are worth the money? Is it sufficiently accurate if you repeat the same cut on the same piece of work? Will it easily cut 5mm of acrylic or plywood?
    Feb 2012
    387
    small laser machine
    Hi ,
    we would not like to suggest K40 with moshidraw, this is not a mature machine ,and if laser machine price is below USD2000,don't cosnider,if thik about small working area but can cut 5mm acrylic or plywood,we would like to suggest LG3040 with 40 or 60w tube ,
    Any others,feel free to ask me
    Best Regards
    G.WEIKE LASER
    [email protected]
    Quote Originally Posted by fishface View Post
    Hi Smiffy
    Jun 2013
    4
    Interesting thread! Not that I'm not still puzzled ;-)
    I'm also looking for a small laser for engraving anodized aluminum (probably with a thermark product - definitely can't afford non-CO2 lasers) and perhaps cutting some mylar films.
    Principally I think the Chinese machines might do the job - but I'm (also) quite worried about the software. I'd hate to spend a lot of time and/or thrash a lot of material/parts because of lousy software. However, the more "serious" manufacturers seems to avoid listing prices at all cost* - making me pretty sure they are way out of my price bracket. For example Epilog has hidden a quote in their FAQ: "30 watt starts at $7,995 (US Price Only)" - pretty much confirming that I don't need to waste my/their time on looking into this - disregarding how nice and functional they might be.
    Still there must be someone somewhere that has made a decent machine with decent software/interface somewhere in between the ~550USD lasers from China and the 8000USD lasers from US?!? I mean except for the laser tube it's not rocket science... So maybe an "upgraded quality" china machine with some India/EU/US-developed software? ;-)
    If anyone has found some - Please share... :-D
    PS: I never understood why companies selling standard products would hide their prices? I will never again spend time talking to sales people or FAEs without having a least an initial price indication. Seems everybody think they can sell anything as long as they get to talk to a potential customer. I don't think it works with engineers - and for my and at least a few of my colleagues it works the opposite way: The lack of pricing (low or high) often automatically disqualifies them!
    Jan 2011
    242
    FYI, anodized aluminum engraves on a laser without any additional coatings. It marks white.
    Jun 2013
    4
    Thanks for your comment:
    Quote Originally Posted by RossMosh View Post
    I guess it burns away the color pigment? Or is it the entire anodization? I worry it might end up in a not so nice "self-anodized" finish....
    I've also read it's more of "whiteish" than white (?) - at least with the cheap lasers (most of the Chinese actually deny their lasers can work with anodized aluminum - and usual a "no" from that area of the world should be taken very seriously ;-)
    How is your experience?
    In any case I'm fairly confident the white will be very low contrast on a clear anodized aluminum surface? So for those I think the thermark might be a valid option... (Even though we actually does not need high contrast - but the viewer should not be in doubt if the surface is smudged or intentionally marked ;-)
    Jan 2011
    242
    People have lasered anodized aluminum for years and years. Google it to see what it looks like. Any laser can mark colored anodized aluminum. What you're left with is a whitish mark that isn't quite raw aluminum but isn't quite anodized. I don't exactly know how to explain it but you're taking off layers but not all the layers. It marks fast with low wattage and the appearance is good.
    As for marking clear anodized black, well, it doesn't work all that well. Cermark/Thermark has an option but it's slow and the results can be hit or miss. I would think a YAG would be a much better choice for this kind of work. Marking aluminum takes a serious amount of heat and standard CO2 lasers typically aren't the best machines for this. A lot of people also do electro etching on aluminum.
  1. Add US made laser module to Chinese laser?
    By glintid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-02-2012, 08:43 AM
  2. Optional Acessories Introduction of GWEIKE LASER / CHINESE LASER
    By Melody-gweike in forum News Announcements
    Last Post: 04-14-2012, 02:37 PM
  3. Shocking experience with "York Laser" Laser Engraver
    By klevabuga in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-09-2011, 02:02 AM
  4. My experience on buying (righ now) a Chinese laser
    By keops777 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-23-2009, 12:36 AM
  5. Good books on cnc and laths ? and any has experience with cheap chinese spindles?
    By Dark-Angel in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2008, 01:03 AM
