587,345 active members*
3,519 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > FlashCut CNC > Fusion post processor for a milling machine and FC?
    Nov 2009
    4415
    I have a typical 3 axis milling machine. It does have an 8 tool changer etc. It runs FC 4.5. I am trying to get my machine to respond correctly. I was told by FC that I needed to edit the post processor to disable G54-59. Can anyone verify this is the case or why? Does the controller take precedent if so? There are fixture offsets within the controller.
    A lazy man does it twice.
    Sep 2009
    1856
    Re: Fusion post processor for a milling machine and FC?
    Did you try the post here Autodesk CAM | Post Library
    http://danielscnc.webs.com/
    [SIGPIC][/SIGPIC]
    Nov 2009
    4415
    I went there and dl’d the FC post. After my experience with the Fanuc post I am hesitant to hit start.
    I posted the code from both processors against each other so I could tell what was changed. There is some difference but I cant tell what it would cause.
    I do know that wherever my machine was going at 500ipm wasnt where it was supposed to be.
    I am starting to think my machine thought G54 was where my tool setter was.
    Sent from my iPhone using Tapatalk Pro
    Sep 2009
    1856
    Do you have G28 safe retracts set to yes
    [SIGPIC][/SIGPIC]
    Nov 2011
    51
    Quote Originally Posted by Fastest1 View Post
    Attached is the 3 axis and 4 axis flashcut cnc post processor I use everyday with fusion 360. works like a charm.
    as for the G54-G59 there is an option in the flashcut software to ignore G54-G59 under controller > programming > G-code > uncheck where it says execute G54-G59 this is what I did. I also have a custom post that I modified to include 4th axis moves that I also use daily for my indexer. both post are included in the attachment. let me know if you have any questions. I would be glad to help in any way
  1. How to Develop Post processor for milling machine in Catia V5
    By khan133 in forum Tormach PathPilot™
    Last Post: 12-01-2017, 09:24 PM
  2. Post-Processor for BZT Milling Machine
    By tsombnik in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-04-2017, 10:32 AM
  3. Fusion 360 Post Processor
    By brianbonedoc in forum Smithy
    Last Post: 03-10-2017, 05:55 AM
  4. fusion 360 post processor
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 03-20-2016, 08:20 PM
  5. SlantPRO post processor for Fusion 360.
    By adamvs in forum Tormach Slant Lathe
    Last Post: 02-26-2016, 05:43 PM
