587,600 active members*
4,279 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > 4 Axis TB6560 CNC Stepper Motor Driver Board Controller with a GGC usb
    Apr 2003
    32
    I have a 4 Axis TB6560 CNC Stepper Motor Driver Board Controller.And the motor hook up.
    A+
    A-
    B+
    B-
    I tryied
    A+ as A red
    A- as a black
    B+ as B white
    B- as b green
    The motor are on but all that happens the relay clicks
    2 wrongs don't make a right
    But 2 Wrights makes a Airplane
    Kevin Matney
    www.Matneymodels.com
    734 - 848 - 8195
    "IN GOD WE 'TRUST "
    Jan 2010
    50
    This might be a shot in the dark but I have always hooked up 4 wires as
    black
    red
    green
    blue
    Apr 2005
    281
    If you have an 8 wire motor (23-205-DS8) you are partially correct. The motor has 4 coils and you are connected to each end. Connect the yellow and blue together and also connect orange and brown together. If it does not run then reverse the red and black connections.
    Try it. John
  1. need help with 3 AXIS (TB6560) CNC DRIVER BOARD
    By Jason Miller in forum CNC Machine Related Electronics
    Last Post: 08-11-2012, 03:34 AM
  2. CNC stepper motor driver board TB6560
    By Chaparro1973 in forum Spanish
    Last Post: 12-27-2011, 07:00 PM
  3. TB6560 4 Axis CNC Motor Stepper Driver 3A 12-36V
    By vicsrc in forum Want To Buy...Need help!
    Last Post: 03-10-2011, 05:57 PM
  4. 3 Axis TB6560 Driver Controller motor sizing
    By crazydiamond in forum Stepper Motors / Drives
    Last Post: 01-05-2011, 02:21 PM
