587,228 active members*
5,377 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Motors don't run - Mach3- Leadshine MX4660 - UC100 USB
    Mar 2011
    61
    Hello all,
    I am quite new to Mach3 and I think I need some help here with Mach3 in combination with the MX4660 from Leadshine and the UC100 USB controller.
    I am not sure where to put this because I am not sure what is the problem the Leadshine MX4660, Mach3 or the USB controller.
    Problem: I can't get the motors to run.
    Hardware:
    Leadshine MX4660
    UC100 USB
    Nema 23 stepper motors
    - current/phase 5 A
    - Voltage 2.0V
    RPS 369 output voltage 36VDC
    Computer:
    Lenovo Thinkpad
    Software:
    Windows 8.1
    Mach3 trial version
    Power should be correctly connected, I can measure 35V DC output at the power supply and at the Leadshine power connector. While bench testing I don't have an EStop but the connection between + and - is shorted.
    When I power on the MX4660 the green leads next to the motor connectors turn on, no blinking, which should indicate that it is OK.
    After the power was turned on I can't turn the motors anymore, thus I would assume they have power and they are just "holding position".
    The UC100 CNC drive software was installed without any error messages. During Mach3 startup I choose the the UC100 controller and not the LPT port. The blue and the green LEDs on the controller are "on" and not blinking, which according to the manual indicates normal function.
    Attachment 297136
    Here are my Mach3 motor settings:
    Attachment 297134
    I looked again in the Leadshine MX4660 manual and found this advise:
    Attachment 297138
    Not sure what to do with that, how to find out if the step&direction voltage is lower than 5 VDC?
    Looking into the trouble shooting section I found this table.
    Attachment 297140
    #1 is OK I can measure power output 36 VDC
    #2 the stepper motors come with four wires, this seems to be pretty forward, they are connected according to the manual:
    A+ black
    A- green
    B+ red
    B- blue
    #3 the E-Stop connection is shorted
    #4 as I said I measured the power supply voltage at the power connectors and I is 36.11 VDC. There is no mechanic system yet.
    #5 I am not entirely sure how to do that or I did this correct. I found the settings under "Motor Tuning".
    Attachment 297142
    and increased "step pulse" to 5 us, not sure if that is helpful.
    I turned OFF the "Charge Pump" setting the switch to the "on" position according to the manual.
    I set the output current to 6.0A via the switches.
    I set the Micro Step resolution to 1/16 - 3200
    And last not least I can see the input from the Jog Wheel in the UC100 in/out monitor.
    However ... the motors are not running
    Any thoughts ... ideas? I have the feeling that I miss something in Mach3 but I am not sure. I probably should test this on a normal parallel port but I don't have one unfortunately.
    I appreciate every help and advise.
    Chris
    Aug 2015
    Re: Motors don't run - Mach3- Leadshine MX4660 - UC100 USB
    i feel your pain
    nice idea the mx4660 ALTHO ***** info and help around hence how Ive found this post looking for my own problem
    IF this is the same problem i once had ?
    go to port & pins / output signals and enable charge pump
    charge pump - enable | port - 1 | pin number - 16
    Mar 2011
    61
    Hello,
    thank you for your answer!
    Meanwhile I figured it out, or better meanwhile it works and I am not entirely sure what finally helped. My last changes where the "Charge pump" and the amperage, but it still didn't work. Then Mach3 badly crashed and I had to restart my computer, after that it suddenly worked and I could run a G code.
    At the end it was quite easy, at least easier than I thought in beginning.
    Chris
    Apr 2013
    14
    Quote Originally Posted by fugley View Post
    i feel your pain
    You fixed my problem after replacing my mx4660! Thank you\
    Mar 2022
    13
    Power should be correctly connected, I can measure 35V DC output at the power supply and at the Leadshine power connector. While bench testing I don't have an EStop but the connection between + and - is shorted. https://www.dumpsleader.com/PL-100-exam-dumps.html
  1. UC100 and jumping, stuttering motors
    By rlrhett in forum UCCNC Control Software
    Last Post: 09-24-2015, 06:27 PM
  2. Replies: 9
    Last Post: 08-30-2015, 01:23 AM
  3. Nema34 electronic for a 48x60 build with Leadshine MX4660 and KL34H260-60-4A
    By javabugz in forum DIY CNC Router Table Machines
    Last Post: 10-16-2014, 04:21 PM
  4. Leadshine (Integrated Easy Servo Motors)
    By gzm.pepe in forum Waterjet General Topics
    Last Post: 01-11-2014, 03:19 AM
  5. Replies: 0
    Last Post: 07-13-2012, 10:32 AM
