Ok Heres the problem.
Often I am required to engrave useing a .04 endmill or carbide center drill.
My machine hits it soft -z limit about a inch from the top of the table useing a collet tool holder. Is there a way to turn off the lowed z soft limit?
I am sure there is room because I can lower the tool to the table with the wheel crank. then I get fault #318 stored stroke length.
