587,436 active members*
3,695 visitors online*
Results 1 to 9 of 9
    Jun 2003
    3312
    Smile SLA7051 Board - Ready for Prime time ?
    I finally finished the design of a compatable single axis board for the Allegro SLA7051. It's not built, but I would gladly work with a person to make sure all the bugs are out if any. http://www.pminmo.com/sla7051/sla7051.htm
    Spec's on my website http://www.pminmo.com/
    Phil
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jan 2004
    111
    Hey Phil. I have one board nearly complete and two more boards that are yet to be populated. I am currently working right now so i will have to take some time to get one working. Did you change the design much from the original you had on your site. I worked out the two resistors for the sense part but i was wandering what you were using. I ended up with 1.1 ohm which doesn't seem right.
    Have a good one.
    Dave
    Jun 2003
    3312
    Schematic a little, went to two resistors for the sense resistors. The one change I did put in was the sync pin. I wound up using the Allegro/Sanken recommendation out of their data sheet. Information on the 7051 is very limited, so I just decided to go that way. Only added a fet, resistor and capacitor.
    Phil
    Sep 2005
    SLA7051 Board Status
    Hi Phil and others
    I'm a newbie and wonder if the SLA7051 board is working or still in progress. If it is, it will be the candidate for my very first stepper controller. I have 4 of those SLA7051 at hand and would like to put those in action.
    Jun 2003
    3312
    handystuffs,
    I have not built one, and I don't know if there are any issues or not. There is one minor thing I probably would change, putting a zener inline with the lm317. I would make this offer, if you want to etch a board and send it to me, I would build it and test it. I have the parts, just not into etching, and don't really have a need.
    Phil
    May 2005
    150
    phil
    do you have an eagle file for the sla7051 board.
    i checked the data sheets and the sla7052 looks like a pin for pin replacement for the sla7051.
    am i rite, if so then i could use my chips on this board.
    if it is the same pin out then this could work for both chips.
    Jun 2003
    3312
    I believe you are correct they have the same pinout. Your post is very timely I just completed most of a 7051 checkout. Thanks to another Zone member for etching a board for me. Pic attached. Couple of things I want to change. I can say the circuit posted works, short of checkout of the sync circuit. I don't have the fet yet. Changes are clearance, I'm going to add a enable circuit, and a zener to allow the normal LM317 to be used.
    Jun 2003
    3312
    I've updated the files on the website today with what I learned on the protoype. Basically chaned some component and land spacing to make it easier to build. http://www.pminmo.com/sla7051/sla7051.htm
    Changed some clearance issues, added a zener and resistor to eliminate the need for a lm317HV if your running max power supply voltage. I must say at 24V this little baby impressed me.
    May 2005
    150
    phil
    i got the updated board.thanks for the pm.
    can your cnc do fine enough work to do pcb work.if so here is an eagle file that will create g-code from the board design in eagle.
    Attached Files Attached Files
  1. New board help requested
    By pminmo in forum Open Source Controller Boards
    Last Post: 09-30-2008, 11:10 AM
  2. Building Phils sla7051 board
    By TinkerDJ in forum Open Source Controller Boards
    Last Post: 05-09-2005, 07:16 PM
  3. Time to wade in ready or not.
    By fair451 in forum CNC Wood Router Project Log
    Last Post: 12-17-2004, 05:14 PM
