587,920 active members*
3,354 visitors online*
    Jul 2013
    42
    Default rapid speed?
    I don't run my GR-510 over 50% and I am curious if there is a way to set the startup default rapid speed to 50%. Is that possible?
    Thanks!
    Jul 2005
    12177
    Have a look at Setting 10 LIMIT RAPID AT 50%
    Jul 2013
    42
    I enabled the setting, but it still powers on at 100% and I'm still able to go to 100% in a program.
    Mar 2010
    1852
    Something tells me you hit the button for setting it, but did not write it and confirm. Check to see if it still on or if it back to off.
    Mike
    Jul 2013
    42
    Ah yes, the ol' Write key. Thanks!
  1. Low rapid traverse speed
    By megaisomot in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2008, 02:36 AM
  2. Default kernal speed in Syil inch profile
    By thackman in forum Syil Products
    Last Post: 12-17-2007, 10:41 PM
  3. rapid speed
    By drafterman in forum DIY CNC Router Table Machines
    Last Post: 11-03-2007, 05:31 PM
  4. rapid speed
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2007, 03:23 PM
  5. Default feed override and manual jog speed settings?
    By InspirationTool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-22-2007, 11:04 PM
