587,414 active members*
3,205 visitors online*
    Sep 2015
    25
    Vfd selection
    I have old yaskawa spindle servo motor , I need to mount new VFD and run the spindle. Turning center FANUC control. Thanks in advance. Any suggestions guys.
    Sent from my Moto G (5) Plus using Tapatalk
    Nov 2013
    4516
    Re: Vfd selection
    to get the best out of a servo you need a servo drive not a VFD.
    If you get a VFD with sensorless vector control it will run a servo adequately but note that you'll get only a 10:1 to maybe 50:1 speed
    range. A genuine servo drive you'll get 5000:1 easy.
    Craig
    Sep 2015
    25
    Re: Vfd selection
    Thanks for reply
    Yaskawa spindle Drive : CIMR-VMW2015-SVC.
    Yaskawa spindle motor : UAASKB-15CA3.
    This is drive and model no. Somebody saying this motor is not servo.
    And some people's using teco drive they're running the spindle. I'm getting confused.
    Nov 2013
    4516
    Re: Vfd selection
    from the pictures that looks more like an asynchronus spindle motor rather than a servo.
    AC servos have permanent magnet rotors and are therefore synchronous and usually have an encoder that allows for position control, ie have an index
    signal. Also they have commutation signals for the drive.
    Depending on the source of the description some decribe the attached Yaskawa encoder not having an index output and therefore not position
    capable, neither do any of the descriptions make any mention of commutation signals, which tends to lend credence to the notion that this is an
    asychronous inverter-ready spindle. That being the case any suitably sized VFD will work.
    Craig
    Nov 2013
    4516
    Re: Vfd selection
    one test that you might do to establish whether it has a permanent magnet rotor is with it sitting on the bench, dissconected from
    all power, short two windings together and turn by hand. If it has a permanent magnetic rotor it will attempt to generate high currents in
    the short and there will be extreme resistance to turning. If however the rotor is not magnetic then there will be very little or no resistance to
    turning the shaft by hand.
    Craig
    Sep 2015
    25
    Re: Vfd selection
    Thanks for suggestions.
    Due to covid 19 we're unable to go outside. I'll check and reply.
  1. Need to bypass Random selection/shortest path tool selection method
    By Tizbass in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2012, 02:38 AM
  2. VFD Selection
    By AK_Five-O in forum Phase Converters
    Last Post: 01-30-2011, 02:16 AM
  3. Need help with saw selection
    By thedave in forum Uncategorised MetalWorking Machines
    Last Post: 11-19-2010, 06:44 PM
  4. Please help with VFD selection
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-03-2010, 06:52 AM
