587,446 active members*
3,202 visitors online*
    Dec 2009
    16
    Wiring Stepper Motors to drivers
    Hello - I just bought my stepper/Driver/Power Package specically:
    CNC 4 Axis Package with 425 oz-in motor and KL-4030 Bipolar
    Driver with 36V/9.6A Power Supply
    Can I connect a RJ45 cable from the stepper to the driver?
    Would be nice since there are so much accessories for RJ45
    Eugene
    Aug 2009
    392
    Quote Originally Posted by xyzeugene View Post
    Eugene
    CAT-X Network cables are only 24awg, which can handle a maximum of 3.5A. You'll need to use something with a larger gauge wire.
    Feb 2005
    130
    yes, for one wires limit is 3,5A for awg24
    http://www.powerstream.com/Wire_Size.htm
    but, if we connect parallel 2 wires -->> max current rise up to 7A
    we need 4 wires for 2 phase bipolar stepper... but ethernet rj45 cable have 8 wires
    it is good idea to use twisted pair as waveguide for powering phase of stepper (2 phase)
    Oct 2005
    2392
    That's single core wire isn't it? You can't bend it more than a handful of times before it snaps.
    Aug 2009
    392
    Quote Originally Posted by markcomp77 View Post
    Ahh, good point. I was under the impression it only had 6 for some ridiculous reason
    Feb 2005
    130
    maybe ethernet cable is good to connect motors because of current..
    but, I like use higher diameter shielded cables...
    0.5mm x4 - 4A motors
    1mm (1.5mm) x4 - 8A motors
    and... strong plug is important too
    this is photo of control unit (3 x 7,8A 80V etc)
    black plugs - 10A current possible... shielded cables 4x1mm
    silver socket - easy up to 4A (6A)
    smaller unit
    cables for 4.2A motors (silver plugs)
  1. Wiring stepper motors to drivers
    By John DiBernardo in forum Stepper Motors / Drives
    Last Post: 06-06-2012, 01:23 AM
  2. Wiring up motors drivers and break out board
    By Nitroghost in forum Automation Technology Products
    Last Post: 09-22-2011, 07:41 AM
  3. Sherline CNC - Suitable Stepper Motors and Drivers
    By FusionTiger in forum Benchtop Machines
    Last Post: 11-16-2007, 04:51 PM
  4. Stepper motors, drivers etc
    By _taz_ in forum Stepper Motors / Drives
    Last Post: 08-05-2007, 12:49 PM
  5. Replies: 3
    Last Post: 05-22-2005, 03:55 PM
