587,375 active members*
3,238 visitors online*
    Aug 2013
    Trotec Speedy 300 leaving banding while etching
    So the trotec support guys have been fairly useless in helping us service this machine. It has a fairly new (refurbished) tube, that they are wanting to replace. The problem we have is that while doing large, deep etchs, the laser intermitedly powers off and leave bands of unetched material running through the engraved pattern. I will post pictures of this, but its a fairly intuitive as to what is happening. Anyone have these issues? Initially we thought that it was tickle power problems, but we bumped it from 180 to 220 with no noticiable change. The trotec guys are in the process of sending us a new tube but I sure would love to nick this problem in the bud before all that. We have done other large scale suggested overhauls only to find small components being the culprit. Thanks guys.
    Nov 2009
    314
    Hi ,
    Do you mean the engraved effect is not perfect ,not flat as if you can see visually that one or two lines were power off or not as big power as the others ?
    We once have similar problem and found it was a unstable voltage cause .
    Hope you haven't make the overhauls yet ~~
    Best regards,
    Mary
  1. trotec speedy 500,200w machine sale
    By Harsha Nayuni in forum Redsail Laser
    Last Post: 08-18-2014, 05:23 PM
  2. trotec speedy 25w-laser tube
    By wouldliketoknow in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-08-2014, 04:17 PM
  3. How do you like your Trotec Speedy 300?
    By sosullivan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-10-2013, 09:08 PM
  4. I was thinking about buying a used trotec speedy c40
    By tomislav_kozul in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-05-2011, 06:32 PM
  5. Edge Banding Problem Help Pls...!!
    By kedkem in forum Glass, Plastic and Stone
    Last Post: 03-11-2011, 01:22 PM
