587,647 active members*
3,669 visitors online*
Results 1 to 20 of 21
    Mar 2010
    accuracy of home made CNC machine
    Hello,
    I'm new here (is it the correct forum?) and I hope to build a nice CNC machine.
    also I saw at:
    http://buildyourcnc.com/yrailsandnut.aspx
    machine which looks nice. however, does anyone can estimate the accuracy for this kind of machine?
    I hope i can get 0.1mm (~0.0004") accuracy. (actually I know it is not accurate but it is good for me and I don't know if it is realistic for homemade machines)
    According to your knowledge and experience is it realistic?
    thanks
    Apr 2004
    5750
    Quote Originally Posted by spaltiel View Post
    Hello,
    also I saw at:
    [The accuracy of a machine like that would be low. It looks like they're going for the cheapest possible build, with the least equipment required, and the most easily sourced hardware. There's nothing wrong with that, but the amazing thing about it is that you can build a CNC machine that way at all, not its ultimate accuracy.]
    [I think you're off by a decimal point, but even +/-.004" overall accuracy would be better than I'd expect from a machine like that. +/- 1mm (.04") is more like it. However, there are lots of things you can make that don't require great precision. If you want better specs, you'll have to go with higher-quality components - like acme screws instead of hardware-store allthread, precision linear rails and trucks instead of skateboard bearings riding on aluminum angles, and a metal frame instead of MDF. ]
    Andrew Werby
    www.computersculpture.com
    Jan 2006
    628
    I don't want to sound negative, but .1mm accuracy seems very unlikely (impossible) with that design and components.
    If you check the specs on even many medium and higher-end commercial machines (using expensive linear rails, ballscrews, etc) they never claim to have that level of accuracy. They may have that type of resolution, but repeatability is more like .001" to .004"
    With 1/4-20 threaded rod, MDF, skate bearings, etc you're going to be limited. I couldn't say to what degree of accuracy, but (.1mm/.0004") seems unrealistic. Backlash, racking, staying square, etc. They are all going to be issues.
    Steve
    .1mm accuracy on a home wood cutting router is probably not going to happen . wood working doesn't need that kind of high precision . I would recommend away from building that and look at joecnc plans or the jgro , these are better proven builds and are fairly straight forward to put together . if you do some searching around the forum you will see what the rest of us have done and maybe you will be able to come up with your own design that can work within your budget (if you have one) . regardless which way you go there will be plenty of help available to help you build a much better design if you ask for it
    some plans to look at
    http://www.cnczone.com/modules.php?n...warticle&id=24
    http://www.cnczone.com/modules.php?n...warticle&id=71
    and a few others http://www.cnczone.com/modules.php?n...category&cid=2
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Jan 2006
    628
    Yeah, absolutely look around and see what fits your needs/budget. There are some great, proven designs that don't require much more (time, money) than the plans you're looking at - but could provide much better accuracy and performance.
    What are you hoping to do with your machine? What types of materials will you be cutting? What types of projects do you envision? People may be able to offer more guidance based on what your goals/needs are.
    Steve
    Mar 2010
    Quote Originally Posted by stevespo View Post
    Steve
    I hope to be able of making 3D parts from plastic and wood
    and maybe i need to be more specific regarding the accuracy.
    I design parts in mm and I want that the mistake in the part size will be 0.1mm I hope. I thought that CNC machine are very accurate. Do these parameters change the ability to realize such a machine at home?
    thanks
    thanks
    a $100,000 cnc is very accurate an mdf home built cnc won't be near as accurate , the precision that you are aiming for is far beyond what most manufactured parts are toleranced for aside from bores and other special features but for general metal machining + or - .005 inch tolerance is fairly common , .1 mm is equivalent to 1/9 of the thickness of a piece of lined paper , so without understanding what types of parts you plan to make I would have to assume that the accuracy that you desire is unnecessary for wood or plastic
    Jan 2006
    628
    Actually, the original unit conversion was incorrect (we didn't notice).
    .1mm = .0039" = .004" (4 thousandths of an inch, ~diameter of human hair, ~thickness of a piece of lined paper, etc)
    That type of accuracy can be achieved with a DIY router, but depends heavily on the components, design, care taken, etc. It's not necessarily easy or cheap. An inexpensive router can have that much runout alone. Flex in the frame, backlash, endplay, etc.
    You'll have to really understand all the variables involved and make sure the design has each one of them covered to reach and maintain that type of accuracy.
    Steve
    Jun 2004
    6618
    I do have that kind of accuracy on my shop built router now. Initially I had about .005" I think and now that I added double ball nuts, it cut that in half. My shop built mill is more accurate than that.
    My router though does ride on skate bearings, but is made mostly of steel with a few thick aluminum plates thrown in. Not MDF. MDF will be part of your limiting factors. Threaded rod would be the other. You can get anti-backlash nuts for those too though, so then it really comes down to size and design.
    I think if you threw just a little money at a very small machine built with these type parts, you could just get to .004" without too much trouble.
    Lee
    Mar 2010
    Steve
    sorry for the mistake (accidentally I did type extra zero)
    I do understand these parameters and I'll do my best to get good result.
    I'll try to build the machine step by step and later I'll decide how and what to improve.
    Mar 2010
    Quote Originally Posted by LeeWay View Post
    I don't understand why MDF is limiting factor.
    My plan is to use aluminium L shape as rod and skate bearing as rider.
    Is the MDF rigidity is the main problem? or something else?
    Steve
    oops
    ya I agree that type of accuracy should be fairly easy to achieve with the right setup
    you'd be far better off using steel angle than using aluminum angle , mainly for wear and strength
    Jun 2004
    6618
    If building pretty small, then MDF might be okay. Just not a very versatile material. I can't use it here because of humidity. It readily accepts moisture unless it is sealed. Easily done though. Others use MDF for their machines with okay results.
    I just tried it as a table material here on my router and it did not last long at all.
    Personally I would chose a plastic or a baltic birch plywood over MDF. If for no other reason than fasteners work better. You can get screws specifically design to use with MDF too though. If you expect to upgrade the machine soon, then MDF might serve you well.
    I won't buy another piece of it for anything though.
    Lee
    Mar 2010
    Thank you all. Your advices are very helpful.
    I will try the MDF with the aluminum rods as my first CNC construction.
    Be aware that the skate bearings will probably wear the aluminum by more than .1mm.
    Mar 2010
    I finished building the construction. I used MDF and aluminum rods.
    now I need electronics but I thought maybe you guys can help me.
    Does anyone heard on "www.probotix.com" ?
    Do you recommend them?
    Mar 2010
    does anyone know "http://www.kelinginc.net"?
    Feb 2010
    331
    yes, they are very popular here. i am looking at them for parts for my own build.
    Mar 2010
    Quote Originally Posted by Zygoat View Post
    thanks, BTW I saw your design and its looks very nice
    Feb 2010
    61
    I use this set from Keling, they were very helpful and quick to ship.
    G540 4 axis package (One G540 + Four
    KL23H284-35-4B (1/4” Dual shaft with a flat) 387 oz-in + one KL-350-
    48 48V/7.3A 115V /230V power supply: $544.95
    I too built a MDF table (4'x8' based on the Blacktoe), to comment on the use of MDF I would say the only issues I have are with the V-Groove bearings and aluminium angles. They give me a bit of slop (until tighted up), the MDF works very well though. I have built several large shop tools from MDF and have used them for years.
  1. Home Made Injection Machine
    By Rob_M. in forum Moldmaking
    Last Post: 11-12-2012, 02:47 AM
  2. Home made ATC
    By pstockley in forum Uncategorised MetalWorking Machines
    Last Post: 11-09-2009, 11:12 PM
  3. Home made encapsulating machine?
    By tybrenis in forum Community Club House
    Last Post: 01-15-2007, 11:04 PM
  4. Linear Motors for a home made machine?
    By NEATman in forum Linear and Rotary Motion
    Last Post: 05-12-2006, 02:30 PM
  5. Home made CNC mill (and some products made by it)
    By gcamlibel in forum DIY CNC Router Table Machines
    Last Post: 04-05-2004, 11:54 PM
